1984 K5 Blazer
Old 05-12-2023, 10:27 AM
  #581
Bgbldodge's Avatar
Water pump, thermostat, and thermostat housing ordered. Going to pick them up from the parts store this afternoon along with a power steering pump pulley puller so I can get that swapped on to my PSC pump. Doubt I get anything done this weekend since it’s Mother’s Day but you never know.
strutaeng (05-12-2023)
Old 05-12-2023, 04:39 PM
  #582
Bgbldodge's Avatar
Well damn. Got some time and started assembling stuff. Went to check the power steering bracket on my PSC pump and wouldn’t you know it, dang line is in the way and won’t let the serpentine bracket bolt up. Looks like GM changed pump design just enough between 1985 and 1990 that my brand new pump won’t work on my serpentine setup.
Old 05-12-2023, 05:18 PM
  #583
strutaeng's Avatar
Is that the little reinforcement bracket that bolts to the side of the block? The pump still bolts through the front, right?
On my 99 Silverado when it still had the 4.3 I removed that little reinforcement bracket. I can't recall why, and it was a long time ago when I changed the PS pump maybe? I think I ran it like that from maybe 175k miles to 260k miles when I pulled the 4.3. That photo jogged my memory because I was cleaning out my garage recently and came across that little bracket.
Maybe you can cut the bracket and re-weld a kink from extra steel stock to clear the tube? Or just cut it off so you only use one stud?
Old 05-12-2023, 08:27 PM
  #584
Bgbldodge's Avatar
They don’t line up on the front either. About a 1/4” off and only if the pump is nearly vertical so you can’t get the cap off.
strutaeng (05-13-2023)
Old 05-23-2023, 03:56 PM
  #585
Bgbldodge's Avatar
The following 3 users liked this post by Bgbldodge:
strutaeng (05-23-2023), wretched73 (05-23-2023), zz454Chevelle67 (05-24-2023)
Old 06-13-2023, 07:08 AM
  #586
Bgbldodge's Avatar
Got my mini starter in. Fuel system is plumbed. Getting closer to making noises.
The following 2 users liked this post by Bgbldodge:
wretched73 (06-13-2023), zz454Chevelle67 (06-14-2023)
Old 07-04-2023, 12:28 PM
  #587
Bgbldodge's Avatar
Starter installed. Trans dipstick installed. Power steering pump, belt, and trans cooler lines ordered. Fuel tank rubber straps installed and fuel system connected to the tank.
wretched73 (07-04-2023)
Old 07-04-2023, 12:45 PM
  #588
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
Test starting before you get the accessory drive on?
Old 07-04-2023, 12:55 PM
  #589
Bgbldodge's Avatar
I’m a ways away before attempting to start this thing. I had forgotten that I had cut all the starter wires when I yanked the old motor out so I’ve gotta rewire that whole circuit. Wiring is my last major obstacle to really getting this thing ready to run. That and money.
Old 10-28-2023, 10:16 AM
  #590
Bgbldodge's Avatar
Radiator, hoses, hub, and fan ordered.
Quick Reply: 1984 K5 Blazer
