1984 K5 Blazer
#591
Cooling system is done. Yes I know I need a new upper radiator mount. No, I don’t care the shroud isn’t sealed. This will get me running though.
If you are wondering why the red bushings, I somehow lost the brand new ones I bought a few years ago so I had to reorder and all they had in stock was red. Yes it drives me nuts but again, it gets me running. Plus, red means race truck.
#592
At this rate shoulda just ordered the black bushings on back order smh
#593
You trying to say I’m slow?
Probably right though but I can at least mark the cooling system as complete now and that’s one more item checked off the list. Got all the parts to run the trans cooler, need to buy plugs, filters, and fluids, wire the starter and efi, and then see what happens. I’m off every Friday for the rest of the year so I’ll have time to work on it.
#594
Only busting your chops. Definitely moving at a good pace
I have 5 days left. I want to use one or two for deer hunting. We’ll see.
#596
Been going in January like 4 years straight. I never shoot ****. Trying to go earlier this year.
#597
Deer season in January? Ours ends on the new year.
#598
Managed lease. We get to hunt until February.
And not the managed lease where everyone gets a 14pt buck. It’s just 500 acres of high fenced land that the owner released white tails on.
#599
Transmission cooler is installed and plumbed. Think I’m going to add some support up top for it so it doesn’t vibrate itself to death.
Found the stock radiator mounts for the small block radiator I’ve got. Gotta grab my nut sert kit from dad and then get those installed and that’ll help fix the gap between the shroud and radiator.
Pulled some more wires out and got rid of a couple more boxes of stuff.
Question for those with the Holley terminator, where and or how did you run the harnesses into the cab? These things are rather large and I’d like to avoid drilling a 3” hole in my firewall if possible. Wiring is my next big hurdle.
#600
Why not drill the hole and just put a big ol grommet or somethin?
