1984 K5 Blazer
Old 02-03-2024, 06:29 PM
  #611
Bgbldodge's Avatar
Way over thought this. Just going to tap those two wires into the pink ignition wire and call it good. They are just triggers.
Old 03-28-2024, 04:29 PM
  #612
Bgbldodge's Avatar
Started wiring some things up. Relay for the fuel pump. Distribution block for batt power. Got another block for grounds that I haven’t done yet.
The following 2 users liked this post by Bgbldodge:
The_W (04-30-2024), wretched73 (03-29-2024)
Old 04-29-2024, 09:38 PM
  #613
Bgbldodge's Avatar
Damn I hate wiring. Got the firewall ground attached to the head. Ran a ground from the pulley brackets to the frame using an alternator bolt. Need to find a smaller head bolt for the actual ground on the alternator. Ordered up a bunch of 12/14ga wire to repair the factory harness that’s been damaged. Need to order up so 6ga for the alt to battery. Going to run a cable from body to frame at the rear of the truck. All 0ga. Still need to land a couple of grounds for the wiring harness and a couple of switched 12’s and that will be all done. Like done to where I can turn the key and see it light up and dial in the timing and load the tune done.
Ordered a bunch of little stuff today. New oil dipstick, fuel filler hose, vent hose, PCV and hose, throttle return spring, alternator connector adapter, fuel filler cap, oil filter. So much little crap. Need to order all the fluids, bolts for shocks, bushings for shocks, steering box, extended shock mounts, firewall grommets, air cleaner assembly, stupid crap that adds up.
Anyone around central Texas want to do a wrench fest soon? So much little crap.
Old 04-30-2024, 08:14 AM
  #614
shakenfake's Avatar
Received 1,275 Likes on 972 Posts
You makin the steaks?
Old 04-30-2024, 10:49 PM
  #615
Bgbldodge's Avatar
Tell me the cut you want.
shakenfake (05-01-2024)
Old 05-10-2024, 01:03 PM
  #616
Bgbldodge's Avatar
First time in years this truck has had 12v running through it. Headlights work, blinkers work, starter kicks. Dash lights don’t work, no interior buzzer, there’s no lights inside for the blinkers but the relay clicks. The taillights don’t come on with the headlights but the blinker works. One taillight doesn’t blink or come on at all.
The excitement coursing through me is almost overwhelming and of course the wire and I are going on vacation on Sunday and won’t be back until Wednesday and we’ve got kid things all day tomorrow.
So close to trying to start it.
File Type: mov
Old 05-10-2024, 05:15 PM
  #617
Bgbldodge's Avatar
And that’s where I finished for the day. Need to fill fluids, prime oil, set distributor and timing, fuel filler hose, PCV hose, MAP sensor hose, install O2 sensor, install plugs and plug wires, load tune, add fuel, test for fuel leaks, and then I guess turn the key and see what happens with a motor that was built two years ago that’s being run on a technology I’ve never messed with.
Needed this win. Been down on this project for a long time. Now for some beers and burgers and a nice vacation.
Old 05-11-2024, 01:31 PM
  #618
Bgbldodge's Avatar
What $200 in fluid looks like.
Old 05-13-2024, 10:13 AM
  #619
shakenfake's Avatar
Awesome!!!!
Old 05-16-2024, 09:43 PM
  #620
Bgbldodge's Avatar
Got 60psi of oil pressure with a drill. Also need another qt of oil. 7qts and the dipstick is dry after priming even though it was over full before hand. Supposed to head out camping tomorrow but I’m gonna try and set the timing on the Holley tomorrow and load the tune. ****’s getting real now.
wretched73 (05-17-2024)
TIM Z
05-21-2012 08:04 PM
dewmanshu
06-25-2007 06:00 PM
BlackGMC
11-02-2006 10:49 PM
MNC5
13
11-11-2003 06:46 AM
Quick Reply: 1984 K5 Blazer
