1995 Chevy RCSB LQ4 Pt88mm Turbo Build
Old 08-06-2011, 11:28 AM
  #161
Swerve7rpm2000's Avatar
Yea to slowly take the heat away, ill use the pedal where i can but there will be some spots that might be pretty tough and will have to just use the handle.... Its pretty hard to hold your hand steady and not to mention your going in a circle around a pipe lol
Old 08-06-2011, 12:33 PM
  #162
SCOTT_A's Avatar
Yeah, Pipe welding around small diameter tubes, out of position and confined in tight portions of the cab has got to be challenging.
Do anything you can to brace that hand steady. Another huge help can be a magnifying glass in your helmet, they sell them at welding supply shops that clip right behind the shield glass.
Old 08-10-2011, 05:36 PM
  #163
paulhstratton's Avatar
Hey man could you do me a big favor and tell me what the Part # for the fuel cell you used was?
Old 08-11-2011, 09:19 PM
  #164
Paul its and RCI 20 gallon tank... The make all the 20 gallon tanks the same demensions i belive, just call RCI and get em to make ya one it might take a couple weeks
Few more pictures of the progress
Old 08-11-2011, 09:28 PM
  #165
Ph.D. in HUBRIS
custm2500's Avatar
Looking sexy!
General idea what the cage will weigh. You are using cromoly? Steel is approximatly 125% the weight of cromoly if I am correct?
I am hoping the first time to the track with 100-150 shot I will need a cage. Maybe less nitrous if it works out correctly.
Old 08-11-2011, 09:30 PM
  #166
cttandy's Avatar
Looking good.
Old 08-12-2011, 09:28 AM
  #167
Id have to guess the cage will weigh around 75#'s or less, I also cut weight in other places where I could to retain stock ascetics but I didn't have patience to retain the stock dash so I'll build a Sheetmetal one and powdercoat it....I'm gonna cut the base down on the seats today to lower them in the cab of the truck for helmet clearance on the cage.. If that don't work then I'll just have to go racing seats but I don't see it being a problem
Old 08-12-2011, 09:44 AM
  #168
Registered User
Team Paulie's Avatar
I would kill for two items in that shop, the lift and the coke machine.........
Old 08-18-2011, 09:56 AM
  #169
Bellflower's Avatar
Default Dash
just a thought, but instead of the sheet metal dash, the 88-94 dash work very well with a cage, the bars will run through were the fatory speakers were and all you have to do is notch the speaker grilles, not really heavy either. im in the process of putting mine back together now
Attached Thumbnails 1995 Chevy RCSB LQ4 Pt88mm Turbo Build-0227101540a.jpg   1995 Chevy RCSB LQ4 Pt88mm Turbo Build-0227101539c.jpg
Old 08-19-2011, 07:59 AM
  #170
I wouldn't be able to see over that dash while sitting in my seat I don't think, it's a good idea though I'll check on it, what year is your truck? Thanks
Quick Reply: 1995 Chevy RCSB LQ4 Pt88mm Turbo Build
