1995 Chevy RCSB LQ4 Pt88mm Turbo Build
Old 12-23-2011, 03:29 AM
  #231
Ph.D. in HUBRIS
custm2500's Avatar
So the ultimate goal is 8s now? That thing is a monster!
Old 12-23-2011, 01:26 PM
  #232
Swerve7rpm2000's Avatar
i would dream of 8's custom but with this 4,000# truck im not wanting to push it that hard..... My ultimate goal will be a 9.99 and ill leave the 8's to the Chevstang that im gonna build for my wife in the near future (She thinks its hers) lol
Old 12-23-2011, 01:39 PM
  #233
Str8Ugly's Avatar
Originally Posted by SIC LSX
im bruce burge... i sent a request a few days ago no response
Old 12-23-2011, 01:53 PM
  #234
ill let em know
Old 12-23-2011, 02:45 PM
  #235
Ph.D. in HUBRIS
custm2500's Avatar
I think 8s might be out of the question but deffinatly 9s and I would guess much more solid then 9.99! Only time will confirm.
Old 01-05-2012, 03:23 PM
  #236
Well got the new turbo on and went to make a few pulls on the street after heat cycling the turbo to break it in and noticed when i got home that oil was sitting on the inlet of the turbo.... Not good! So i called the rebuilder and sent it back to get it fixed under warranty, i will say with the 1.32 ar exhaust housing the thing took some rpms to get it boosted up but when it come in around 5000 rpms its a animal for sure.. I sent it back and im trading the guy out my exhaust housing for a 1.0 ar to help with a little quicker spool and hopefully ill get a non leaking turbo back!! Also made a couple extra changes to my wastegate positioning so i wont get the dreaded boost creep ive been dealing with, should have it up and going again next week if my turbo gets done, i just have to finish running my 5" exhaust with my new magnaflow diesel muffler :]
Old 01-05-2012, 04:23 PM
  #237
Slowest turbo build ever!
black00chev's Avatar
Wow, wasnt hitting full boost till 5,000???? When did it start making boost?
Old 01-05-2012, 05:10 PM
  #238
hmm i just started getting into boost around 5000 but took no time at all to hit the mark soon after :] this exhaust hosing was a beast.... But that was in first gear so once i hit boost it stayed in boost
Old 01-05-2012, 05:20 PM
  #239
Jake99's Avatar
I bet the air flow of that 1.32 would make for some wicked power at the hi rpm but with such a slow spool it might hurt the low end more then its worth, unless you had a tbrake and 2step.
Old 01-05-2012, 06:24 PM
  #240
Ok wow, so that housing does lag that bad... I was just wondering if it took that long to reach max boost with that housing or if it just had that much lag to it. That 1.0ar housing is probably going to hit you like a freight train haha.
Quick Reply: 1995 Chevy RCSB LQ4 Pt88mm Turbo Build
