1995 Chevy RCSB LQ4 Pt88mm Turbo Build
Old 01-24-2012, 06:26 PM
  #251
TJ
TJ's Avatar
youve got to build a lightweight crossmemeber. hard to tell from the pics, looks like you might have already cut it up and put plate on the bottom of it.
like the exhaust.
Old 01-24-2012, 07:16 PM
  #252
1989k1500's Avatar
Originally Posted by Swerve7rpm2000
Haha ya i know how it is! Im needing a secondary wastegate and another turbo blanket so ill be down for a bit untill i can sell some stuff i have laying around.... I need to go subscribe to your build to keep me up to date. I have had the AMS 1000 hooked up for a bit with CO2 but havent been able to use it cause overboosting issues cant wait to get it all sorted out. Thanks for the Pic!!
Just put good fuel in it and let it eat. lol
Old 01-24-2012, 08:40 PM
  #253
Swerve7rpm2000's Avatar
Originally Posted by milkey57
Cant wait till you do....you thinkin single digit club? Regardless track vids will be a must
Guarenteed!
like the exhaust.
Yes TJ you are correct, i could prolly drop some weight by incorporating my drive shaft loop in with a light weight cross member! Ill put that on my to do list, just really havent taken the time to do it
You are so right and i have been wanting to do it lol but 22#'s of uncontrolled boost is wicked and i really dont know how high it will go in the upper rpm range!
Old 01-25-2012, 04:43 AM
  #254
Ph.D. in HUBRIS
custm2500's Avatar
Sounds like fear. We don't have time for fear!
22lbs of boost how much hp does that apriximate to? Just the boost alone600-800? You can't controll the truck with it just doing what it wants?
Old 01-25-2012, 09:37 AM
  #255
Cannot control the boost untill i get a secondary wastegates, ill have to bleed off both heads individualy to control boost on this log setup
Old 01-29-2012, 07:45 PM
  #256
Heres a pic of the second 50mm JGS wastegate, now i have full control over boost with the AMS1000 and CO2, went for a test spin and the new turbo on 10#'s feels like the old turbo on 15#'s!! Didnt get to run this weekend cause the turbo seems to be burning oil out the exhaust housing so ima try some different restrictors... Heres a couple pics of the wastegate setup and my polish job on the 91mm
Old 01-31-2012, 01:14 PM
  #257
13 Second Truck Club
LS1FREEK's Avatar
Looks great man!
Old 01-31-2012, 05:36 PM
  #258
Jake99's Avatar
Looks good man, thats a nice shiney hair dryer you got there!
Old 02-12-2012, 11:22 AM
  #259
james8997's Avatar
Hey man what exactly did you have to modify for the kbracing cross over pipe to work?
Old 02-12-2012, 11:56 AM
  #260
It would hit the frame where it goes to the passenger side of the motor by the starter...
Quick Reply: 1995 Chevy RCSB LQ4 Pt88mm Turbo Build
