1995 Chevy RCSB LQ4 Pt88mm Turbo Build
Old 02-23-2012, 03:03 PM
  #281
Ph.D. in HUBRIS
custm2500's Avatar
What size tube is that? I need to make some cross members for my truck. All of mine hang too low
Old 02-23-2012, 07:20 PM
  #282
TJ
TJ's Avatar
very nice man. i like how you used the stock hardware to bolt it back up. something id have done. looks good!
Old 02-23-2012, 07:31 PM
  #283
Swerve7rpm2000's Avatar
1 1/2" i belive!
Yeah TJ i got luckey haha
Old 02-23-2012, 10:07 PM
  #284
SCOTT_A's Avatar
Does the new crossmember elevate the trans output shaft higher than stock, or is it an illusion?
Old 02-23-2012, 10:28 PM
  #285
its actually the same height but i do have a spacer (About 1") between the trans mount and tailhousing...... We decided one day the tranny was pointing down to far causing some of the driveshaft/vibrations, everything seems to work fine since we did this, havent heard from you in a while man where ya been and hows the truck?!?!?
Old 02-24-2012, 07:18 AM
  #286
Lemme rephrase from my last post, the cross member is the height of stock then I used a 1" spacer between the trans mount and tailshaft
Old 02-25-2012, 01:24 PM
  #287
SCOTT_A's Avatar
Im doing fine! My activity with the truck has been a bit low, winter is almost over and ill have my truck back on the street. I installed long tubes and new exhaust a few weeks ago.
Im about to go try and figure my driveshaft angle problem right now... sinse the new aluminum shaft it's almost cleared up... just a slight vibration at 75. maybe ill try a spacer between the crossmember and tailshaft
Old 02-26-2012, 12:19 AM
  #288
he has updates!!!! im working on video!!
Old 02-26-2012, 12:53 AM
  #289
9 Second Truck Club
tarinitup's Avatar
Got the text. Waiting on vids.
Old 02-26-2012, 01:02 AM
  #290
so smooth and easy going down the track. crazy its that fast shifting at 6400 rpm's. This truck will see 8's!!!
Quick Reply: 1995 Chevy RCSB LQ4 Pt88mm Turbo Build
