1995 Chevy RCSB LQ4 Pt88mm Turbo Build
#313
Tell me if this will work: Weldon 2345 and ID2000 injectors?! Hah, now gimmie 3k$
#314
This thing just keeps getting better. It sure does seem like there is a lot of rock when you apply the transbrake though. We have this problem with our powerglide. about every 20 or so launches we have to adjust the band. Turbo 400 may be different though. But its something to look into if you are going to start bracket racing. It would suck to red light because of the rock.
the reverse circuit, low pump pressure or too much converter bleed off can cause these issues as well.
some people may call it a bandaid, but all racers i know hook a line lock to the brake. guaranteed it will never move and make more consistant lights.
#317
13 Second Truck Club
Transmission problems always suck, but when you've got a built trans like yours and you see things like this, it almost puts a smile on your face... Cuz you know you can't damage something like that without making some seriously big power!! LOL
#318
Yes this actually makes me feel good! The fact that i just rebuilt it and put it back in the truck together in 1 day by myself makes me feel even better cause it was the first time ive ever rebuilt one, i replaced 2nd and 3rd gear clutch packs also even though they werent bad at all.... First test drive is in the morning and i know it goes in all gears so far!!! Wish me luck haha.
#319
#320
Well i decided to get some real tires... Countless trips to the track with drag radials gave me a 50/50 chance of hooking, if the track was not soaking wet with vht they wouldnt do anything so we will see if these will do the trick
