1995 Chevy RCSB LQ4 Pt88mm Turbo Build
Old 03-18-2011, 01:17 AM
  #71
8 Second Truck Club
Blown06's Avatar
Impressed!
Old 03-18-2011, 01:58 AM
  #72
LS1TRUCKGUY's Avatar
is this truck gonna make it to the april 16th meet here in houston?
Old 03-18-2011, 09:09 AM
  #73
Swerve7rpm2000's Avatar
Yes it will, but I will not be participating in the racing, I'm gonna be pretty conservative for a bit on this new setup to get some quality drive time in lol, u never know I might make a few passes! Cya there!
Old 03-18-2011, 12:39 PM
  #74
TJ
TJ's Avatar
Originally Posted by Swerve7rpm2000
Cut the ring out of the heat shield
how can i cut the ring out without messing up the braid, or is that ok?
dont know if they will come unraveled so to speak.
thanks!
Old 03-19-2011, 10:36 AM
  #75
nah it wont come unraveled, just take some dikes and cut it from the inside making sure to only cut the ring with just as little of the heat shield involeved as possibe....
Old 03-19-2011, 11:10 AM
  #76
Ph.D. in HUBRIS
custm2500's Avatar
That is an awesome looking truck!!!!
Old 03-20-2011, 09:30 PM
  #77
Thanks i should have some vids up by next weekend, hopefully ill get to make a couple conservative passes at the local track to see where i stand with traction.... I plan on getting a 2-step, line lock, and a 9" narrowed rear in the future in order to blast off the line
Old 03-21-2011, 05:31 PM
  #78
dude, I knew a guy named swerve in Bossier that used to get sucked up in his Mustang by a 4.8 truck, hung out @ Bilbo Baggins..... before he got old he could play baseball..... same guy??
Old 03-21-2011, 06:29 PM
  #79
Bluchevypick's Avatar
Hahahaha if it is the same guy then u should call for a rematch.
Old 03-21-2011, 07:13 PM
  #80
Lmao blake u nut.... Got it on the road today for another tune day and had problems keeping the boost under 15#'s.... Got back home pulled off the wastegate to check the spring, boost controller and such... After taking the wastegate off found this
This is looking into the flange where the wastegate typically connects too, if u look closely the braided strands inside bunched up creating a huge restriction... Cut that flex coupler off and used straight pipe to the wastegate and i can maintain 10#'s, i tell ya what its freaking loud when you step on that gas pedal with a wide open wastegate and its definantly hard to stay in it because your making so much noise it sounds like everythings gonna blow up, guess it will take some gettin used to..... WOT is insane ill get some vids this weekend stay tuned!
Quick Reply: 1995 Chevy RCSB LQ4 Pt88mm Turbo Build
