2000 Chevy Silverado project "Charlie Murphy"
#271
Trucks coming along nice man, looks good. Curious about the ride on the coil over setup? Considering doing the swap to my DD. As someone mentioned before look into derlin for solid bushing material it's good stuff. Just wondering when you tightened the top bushing down did you crank it tight like that or is that the truck compressing it? Just wondering thanks man.
Billy
Billy
I just ordered some acetal homopolymer to play with. I couldn't find some in bushing form so I ordered a 1 1/4 x 12" roll. I'll cut my own bushings.
I started building my license plate bracket. It's way overkill. 3/16" thick steel. LOL.
Consequently, my 110 welder can't penetrate it very well. So I did my best to tack it into place. Tomorrow I'll stop by my buddies place and use his 220.
I cut a piece of 2" x 3/16" flat stock into three pieces and welded them together.
I welded the 2" receiver hitch tubing to the H bracket I made.
Like this:
I'm actually going to trim the 7 prong plug lid a bit and also part of the bracket. That way the license plate will sit back in there farther.
#272
Originally Posted by iregret
Comments like this always make me laugh. It's sure easy to dispense advice after the fact. I'll just throw away all my gear and buy new stuff. LOL. This wouldn't be an issue if I used the Procomp adapter instead of the stud adapter.
#273
I believe his comments were directed towards other people going forward, like me for example. I am eagerly awaiting 2 things, #1 is the weather to shape up, and #2 is how you solve this dilemma. I have ATOMIC's front end parts for the swap and I am wanting to put this mod on my truck very soon. However, if you DO decide to chuck all your stuff I'll send you my address to send the old parts to ;-)
#274
This looks like it may address the issue above, please keep up posted I'd love to hear how you resolve it.
All of this looks trick, I can't wait to see the end results, it's hard to tell from this picture but perhaps maybe you can trim the roll pan and flush mount the trailer connector from the backside so the only thing that protrudes is the cover and the screws ??? I dunno if that'd work or not.
I think a possible solution would be to capture the polyurethane bushing with steel. I may look into this.
After considering it, I don't think Delrin is a good solution. Essentially, when I went with a stud mount design, the bushings are allowing for some movement with suspension travel. With the Procomp adapter and the hiem like bushing mounted in the upper eyelet, it allows for minor movement with the suspension.
Delrin will not allow this. It's too hard and once crushed or conformed, will not bounce back.
Perhaps a solution is to use a derlin spacer below with a polyurhethane bushing above. That may still allow for some movement of the stud mount.
Long story short, I recommend going with the Procomp adapter.
I worked a bit on my overkill license plate mount today.
I cut the lid down. I couldn't completely remove it because it has a hook built into it that holds the trailer plug, or 4 prong adapter into the socket.
I couldn't mount it from behind like you suggested because it would hit the hidden hitch.
I took apart my factory harness and soldered in my led tail light.
I made sure it worked, and put the wires in the loom.
I went over to my buddies house and welded everything solid with his 220 welder. Also, I notched the bracket so it could sit back farther.
I test fitted everything. Looks like it'll work!
What I didn't get pictures of was the stronger welds, painting the bracket black, and drilling the 1/2 inch hole for the pin that holds the whole thing in place.
#275
I see. Thanks for the info. Have you checked the poly bushing out? It might be fine, it might just sit like that due to the weight. The way you have it with the washers I wouldn't see it falling apart but then again. Other then the stud top mount issues how do you like the feel and ride with coilover set up. Btw hidden hitch is license plate is looking good. Thanks Billy.
#276
I'm going to play with a few different materials. I am very hesitant to put in a solid busing though. There has to be some flexibility there. A captured poly bushing could be a possible solution.
#277
are you planning on swapping from a stud to an eye mount? i called ridetech and they said it can be done but you have to have a way of securely holding the shock shaft without scratching it and even soft jaws on a vice have been scratching them.
#279
My QA1's came with upper eyelets. I swapped to the stud mount.
Here's the adapter:
The removal of the eyelet.
I'm not going with the Procomp adapter because it would add a 1.5" to the ride height. I don't have the room to adjust the Coilovers to make up for the adapter. I ordered a longer coilover and spring to take advantage the stud mount.
I've been researching different compounds that may work for me. I seriously discourage the use of Delrin. That's what's been suggested, but it has zero flexibility. That is not what we need here.
Essentially, the bushings are allowing for upper coilover to pivot with suspension travel. With the Procomp adapter and hiem insert, there's a pivot point. If I replaced the stud mount bushings with something solid, it would eliminate movement and stress the stud adapter.
Through my searching I discovered that polyurethane varies wildly in hardness. I also found a pretty cool resource.
BODYMOUNT BUSHING PAGE
It doesn't really say each bushing's harness rating. Energy suspension won't give out that data. Hell, they won't even give out measurements.
I've researched it pretty hard and found this on eBay:
http://bit.ly/1fNZL1k
This sample has a hardness of 95A. That should be in the range of an aftermarket polyurethane body mount bushing. I've already ordered the Delrin, I'll have to find another use for it.
Nah, I'd give them four thumbs up.
#280
honestly i didnt even realize i was pushing ridetech as much as i was until i went back and looked at my posts. my bad, i have ridetechs and i think that makes me just naturally assume that everybody went with them. im actually pretty jealous that your setup is such an easy change.
as far as the delrin mount goes i will have to get pics the next time i have a day off. its essentially a ball cut in half allowing the shock to pivot around it. looks like you got some good info there though. good luck with experimenting.
