2000 Chevy Silverado project "Charlie Murphy"
Old 04-14-2014, 10:27 PM
  #311
WS6 What's Avatar
Good to see you have got quite some miles on your new bushing idea.
Is it holding up well enough to you? It does look compressed quite a bit, to me, but dont know.
did the ride change any?
Im still loving my setup on my 05 tahoe, much better than tbars, but still needs some fine tuning. Right now ground to fender im at 31.5" on a 285/50/20. Been wanting to go to the stud mount, as i think i need more shock travel.
Did not see it, probly missed it, but what shock are you running? ds301?
Old 04-14-2014, 10:46 PM
  #312
I have a gauge for that
Atomic's Avatar
He has the ds303 i think
Old 04-15-2014, 07:20 PM
  #313
WS6 What's Avatar
Hey atomic, this is tahoewhat from TYF, (name wouldnt transfer over for some reason)
I remember that for some reason.
Looking forward to more miles on those bushings.
Old 04-15-2014, 07:41 PM
  #314
Atomic's Avatar
Just curious but at what number of miles would you consider it a success?
54inches (05-01-2024)
Old 04-15-2014, 08:22 PM
  #315
Charlie Murphy!
iregret's Avatar
I don't consider it a success. I consider it a mistake. That's why I told everyone not to go with a stud mount.
Is it functioning? Yes, but I cannot see this as a real solution. There is simply too much weight on that one point. Eventually this will end in bushing failure.
I'm stuck because if I convert to the Procomp style mount, it'll add 1 1/2". I don't have enough adjustment in my coilover setup to to maintains my current ride height.
Eventually, I'll most likely bite the bullet and order the Procomp setup. Or, weld something similar into the upper mount. I'll lower the coilover as far as I can and adjust the rear height to match with the airbags if need be.
The only way I can see to extend bushing life would be to capture the bushings. Even then, they will eventually fail.
My .02.
Old 04-15-2014, 09:19 PM
  #316
Smitty2000's Avatar
I'm glad it's the owner speaking this truth rather then driving with this setup in denial and continuing to try to make it work.
Old 04-15-2014, 10:06 PM
  #317
Militant Minded's Avatar
awesome work man. I just bought a 2000 ecsb silverado that is lowered 5-7. I rub the hell out of my wells and just a bit on the fender with the 22" wheels on it now. Been thinking about trading them for a set of 20s or 18s. But again man awesome work. I appreciate all the detail and hope to follow suite for a ref for others and myself when I get my truck in shape.
Old 04-25-2014, 06:55 PM
  #318
Atomic's Avatar
Hey man I had some washers made to eliminate the need for that bushing using the stud mount. You already have some that will probably work, so you wont need mine. I dont really think that bushing is needed. Give it a shot without it and see how you like it.
Old 04-26-2014, 02:41 AM
  #319
Charlie Murphy!
iregret's Avatar
Can you post up a picture? I think there probably needs to be a bushing of some sort. It is a pivot point.
It would be nice if I had a gopro so I could film what's happening through the suspension movement. I wonder how many degrees that stud moves throughout full travel.
Old 06-18-2014, 12:49 AM
  #320
Charlie Murphy!
iregret's Avatar
I have a slow leak so I removed my front tire.
A couple thousand miles and a few months later, everything seems fine.
I've been really busy, but I'll get back into it eventually.
Quick Reply: 2000 Chevy Silverado project "Charlie Murphy"
