2000 Sierra RCSB, New Project
#33
Picked them up on ebay. Came across an add for the lights and turn signals from a denali because the owner swapped them out for aftermarket black housings I messaged him since in the add he put they were for sale locally to and he could sell at any time. The auction was at $40.00. I told him to name his buy it now price that I would take them. $80.00 shipped it was. Now I just have to sell the denali corners
Thanks, wasn't at the top of my list. They were halfway local and I already had a set of 20" tires. Def like them more than I thought I would. I mainly picked them up so I can lower the truck and not have to worry about trimming ball joints and crap with drop spindles.
#34
Got the projectors in
and got as far as installing them in the denali lights but I had to get up the next morning so instead of rushing it I stopped there.
I spaced the bottom more since it was done in the orignal thread too, I'll see how this spacing works out to see if I need to add more to the bottom.
#35
Well I got the lights mounted and they are awesome. My pattern isn't adjusted the greatest but since these denali lights done have left to right adjustment I might just have to live with it. Heres a few pics. It was late when I finished so I dont have any of them in the truck yet.
Started with the 4-hi mod so I could used the hi/lo feature of the morimoto projectors. On the pass side I used this bolt by the air box.
and I had heard of people lucking out and only having to ground 1 yellow wire, but it didn't work out for me.
Pass side
Drive
So I ended up having to do the driver side, which I used a bolt down on the side of the rad support. There are a couple under the battery that would work on the batt tray, but I didn't want to pull my battery out if I ever had to redo anything.
Here's where I cut my wires to add the new piece to ground. I searched for some yellow wire before finally giving up for this sweet purple wire I found.
Pass side
Drive
#36
Finally got a few pics of the lights up and work
This is as close as I can get them since there's no left to right adjustment on the denali lights, and I can't rotate the projectors with the adapter plates i'm running.
Low beams
lows with fogs
High beams
Few pics of the truck
below the cutoff
Low beams
lows with fogs
High beams
below the cutoff
#40
Forgot I moved my airaid jr intake pics in photobucket and broke a few links. Heres those pics.
Also started installing the headers. Hit a few snags so it'll be awhile until she's up and running. Need to order some new manifold gaskets and spark plug wires. Also sending in my comp to black bear and they are going to sema this week, so thats another set back.
Did get the old exhaust removed though
and got some stuff in from summit
Also got the headers in position. Had to put the driver side in through the top, the pass side went right in from the bottom.
