2000 Sierra RCSB, New Project
Old 01-01-2013, 09:28 PM
  #61
oakley6575's Avatar
Mcgaughy's for me. Didn't know if it should have come with a template or not.
Old 01-01-2013, 09:34 PM
  #62
slonlow2000's Avatar
Well ****.
When do you hope to be done with the install. Its going to look awesome
I'd scan mine for ya but i'm sure after a few uploads and emailing and printing it wouldn't all come out right. Plus mines for 99-01 specific. I see you sig is newer than that.
Hoping to have it done in a couple weekends. I live in some apartments in the next town over from where I keep the truck, so I can only work on it on the weekends. I was hoping to have more done, but I just got the chain hoist last night to pick up the bed.
Old 01-01-2013, 09:35 PM
  #63
GMCtrk's Avatar
You did right by removing the bed. I did my flip/notch install with the bed on and it was kind of a bitch.
Old 01-01-2013, 09:48 PM
  #64
Yeah I needed to clean everything up anyways. As you can see the dealer I bought it from "detailed" it with spray paint. So I need to try and clean off alot of the dirt and paint some stuff, or under coat it. Not 100% sure yet.
Old 01-06-2013, 10:41 PM
  #65
Got the notches marked out
Then ran into a fitment issue, i'm hoping the notch just goes up over this weld in the frame.
So I just pryed it up over the weld and continued
Then I started drilling
Cleaned up the edges and painted it a little
Notch back in for the final time
1 side all bolted in
Old 01-06-2013, 11:08 PM
  #66
Driver side cut out
Backside of the cutout, it goes right through the factory bump stop brackets
And more drilling
It makes a mess
Bolted in, and took out the leaf springs
View of the inside brace to the driver side notch, and where I think the directed say to place the bracket that was removed
Pass side spring pulled and I painted by shackle bracket on the frame, the leaf spring, and the drop shackle since it was rusting pretty good
The driver side was not as easy however, damn hanger bolt would not come out due to the gas tank, and I wasn't about to pull the tank
Pass side almost done, just lacking the shocks
Didn't paint the whole frame rail on the driver side, going to wait until I can pull it outside and wash off all the cross members and paint it all
Back under its own weight for the most part
Old 01-06-2013, 11:42 PM
  #67
UnVmy5.3's Avatar
So your kit in the rear was a axle flip shackles and hangers?
Old 01-07-2013, 09:14 AM
  #68
Its just a normal flip kit, this truck already had 2" drop shackles on it when I bought it. I moved them to the 1" drop hole so it'll be a total of 7" in the rear instead of 6". If it ends up being to much I'll have to hunt down some factory shackles.
Old 01-07-2013, 09:48 AM
  #69
Import Moderator
beastmode's Avatar
Great looking build so far man. Can't wait to see er slammed
Old 01-07-2013, 09:53 AM
  #70
GMCtrk's Avatar
I cut the end off the drivers front hanger bolt. This allowed me to remove it without dropping the gas tank.
Quick Reply: 2000 Sierra RCSB, New Project
