2000 Sonoma 5.3 build
Old 07-27-2012, 10:11 PM
  #51
milktasd's Avatar
A little update before my friend headed to the coast.
Didn't get a chance to take a pic of the brp trans mount installed or of the steering column with its new cover.
And those are umi tubular upper control arms. Going to see if the c6 compressor will clear those a arms.
Old 08-11-2012, 04:10 PM
  #52
milktasd's Avatar
Little update:
Got my cutouts in and installed the umi control arms, steering gear box, and ac compressor.
Old 08-12-2012, 04:47 PM
  #53
milktasd's Avatar
Didnt crank. We are thinking that the original motor might not have been locked up. It might have had electrical issues. No power to the starter and no power to the fuel pump. 0 fuel pressure. We jumped the neutral safety switch under the dash and still nothing. It's getting power to the fuse block and PCM. The dash is lighting up. You can jump the starter and it will turn over, but not with the key.
Old 08-15-2012, 06:39 PM
  #54
milktasd's Avatar
I have a bad fuse block, borrowed one and this happened.
Old 08-15-2012, 10:23 PM
  #55
Bowtie502's Avatar
Woooooott!!!!!!! Congrats!!!
Old 08-17-2012, 04:27 PM
  #56
milktasd's Avatar
Bye bye peg leg.
Old 08-17-2012, 04:33 PM
  #57
nonnieselman's Avatar
Dang man, its turning out great!!
So you planning on driving it down to cruising?
Old 08-17-2012, 08:10 PM
  #58
milktasd's Avatar
I hope to.
Better quality idle clip
Old 08-23-2012, 11:58 AM
  #59
milktasd's Avatar
Little update. The rear end and leaf springs were a pain in the ***. After fighting the leaf spring bolts, i decided to go ahead and order new bushings, bolts, and shocks. I should have my c5 compressor and custom ac lines by next week. The rear end is on hold until my caliper brackets come in. They were left out of the kit I ordered from summit. Started putting the front cap back together. As far as I know, the only thing left to get is exhaust welded up and tires.
Old 08-23-2012, 05:41 PM
  #60
Bowtie502's Avatar
swweeeeeeeeeeettttttttttttttttt
Quick Reply: 2000 Sonoma 5.3 build
