2003 ECSB Build
2003 ECSB Build
Hey guys, I'm new to the forum so this is my introduction/build thread. I have a 2003 Silverado ECSB with a 4.8L and a 4L60e. My goals for the truck are to have 800rwhp daily drivable and reliable. My buddy and I have been ordering parts over the last few days. Here is a list of parts we are going to use.
Suspension:
-Belltech Shocks - installed
-Belltech Sway Bar - awaiting install
-Belltech 2" rear lowering shackles - installed
Wheels and Tires:
-NNBS Silverado Replicas - installed
-Nitto 420s 275/55/20 - isntalled
Engine:
-Isky Triple 12 Cam (arrived, awaiting install)
-LS9 Head Gaskets (arrived, awaiting install)
-ARP Studs (arrived, awaiting install)
-LS7 Lifters (arrived, awaiting install)
-BTR 7.350 pushrods (arrived, awaiting install)
-Texas Speed Ported LS6 oil pump (arrived, awaiting install)
-Trick Stage 3 turbo kit 76/75 - ordered
-Blackbear Autocal - decided to buy EFILive, awaiting to hear from Justin
-Not sure on Meth yet, though it will probably be needed for this power level
-Exhaust - MBRP 4" diesel system with electric cutout
Transmission:
-Jake's Stage 2 without tbrake - ordered
-Circle D Triple Disc (arrived, awaiting install)
-Trucool/cooler lines/fittings - ordered trucool, (lines arrived, awaiting install)
Rear End:
-Trutrac
-3.73s
Fuel System:
-Bosch EV14 80LB injectors (arrived, awaiting install)
-Walbro 450 - (arrived, awaiting install)
-Racetronix hotwire kit (arrived, awaiting install)
Misc:
-Gauges - Autometer Triple Pillar Gauge Pod - AEM Wideband, boost gauge, fuel pressure - installed
-Electric fan and 34" radiator swap, going to buy the harness from LS1fans.com
-Demold and debadge
And a couple pictures
If you have any recommendations, please let us know! Building this with the help of mdwatts11, and this is our first turbo build. We will see how far we get with this and then add parts as necessary.
Suspension:
Wheels and Tires:
Engine:
Transmission:
Rear End:
-Trutrac
-3.73s
Fuel System:
Misc:
-Demold and debadge
A lot of parts came in within the last few days so we spent about 6 hours working on the truck today.
The wheels got banged up by UPS so they will have to wait. We did get the shocks and shackles put on however, the sway bar will have to wait until we can take the exhaust off because it mounts right where the exhaust is welded onto the frame. Judging by the instructions we also need to drop the fuel tank and might as well wait for the Walbro 450 to get here.
Then we did the gauges. Got them all wired for power but only the boost gauge is working fully right now. We are waiting on fittings for the fuel pressure sending unit and we will just wait on the wideband for the turbo.
On to the pics.
On to the pics.
Thanks guys! Its been a while since we have worked on the truck. Got a few things done though! The wheels came in yesterday so had those put on. They are machined NNBS 20s with 275/55/20 Nitto 420s. Excuse the dirty truck.
Also decided to get an Aeroforce gauge and put it in a pod from CubbyCam
And got the fuel pressure gauge hooked up.
A big compilation of parts.
Walbro 450
Triple 12
Circle D Multidisk
Tranny cooler lines
The turbo kit should be here anytime now. Also trying to figure out where to get Jake's transmission shipped because it needs a loading dock. That should be ready soon also.
We are hoping to install everything in a few weeks.
Walbro 450
Triple 12
Circle D Multidisk
Tranny cooler lines
smokeshow
08-23-2015 08:23 PM
