2006 crew cab ls1 and t56 swap and build
Old 05-03-2010 | 12:16 AM
release2063's Avatar
Default 2006 crew cab ls1 and t56 swap and build
heres the build list
ls1 45,000 miles
t56 45,000 miles
ls7 clutch
ls2 flywheel
tsp cam 236 241 @ .660 lift 115 lsa
comp titanium valves springs locks and seals
pacesetter long tubes
k&n cai
h p tunners
the money spent all together was about $2800
im taking it in to jason at tdp to get the rear end built
i have corsa exhaust right now but i think im gonna go with a full fortress performance exhaust package that is true duals 2.5 with an x pipe, cause right now it has a pacesetter off road y and single corsa
here is a video when we were pulling her out
i need some wheels and tires but havent found the ones i want yet
http://www.youtube.com/watch?v=mluNlz8KcXU
Old 05-03-2010 | 12:19 AM
Dewey's Avatar
sounds like it'll be a fun project.
good luck!
Old 05-10-2010 | 02:48 AM
Daryn's Avatar
Formerly darynC-10/23/10
better get some gears... 4.88's or bigger
Old 08-08-2011 | 02:00 PM
dknoerzer's Avatar
Nice truck! Soory I'm a year late, but I want to drop a t56 in my 07. I've seen a couple similar swaps, and mechanically, I have an idea of what it takes. I'm curious about the computer switching from auto to manual. What needs to be done? Do the sensors just plug in more or less?
Also, what did you do about the column shift? Is it just disconnected and removed?
Thanks.
Old 12-18-2011 | 03:29 PM
Default column and computer
on the computer auto to manual your speed sensor plugs in but is tuned for i believe 44 tics per revolution and it has to be changed to 17 tics per revolution and the reverse lights and cruise control you have to wire in and then theres some tuning you have to do as far as torque management and fuel enrichment mode and some other little things but if you pay to get it dyno tuned they will get the bugs worked out for you, it took me about a month of trial and error on hp tunners, but i finally got it myself, and as far as the column i just took the shifter off and unplugged it and put the manual steering column cover on so its a nice clean swap, i got all the part numbers from the a4 to m6 sticky thread and if you need anything else just pm me i hardly get on unless i need something or if im pm'd
ive got a bunch of pics that i still need to post up, im in the middle of getting a shifter water jetted out of inch thick aluminum so i can put my console in, i got a console out of a z71 2006
1bad2k
08-18-2015 10:50 PM
Staggered 02
08-11-2015 08:54 AM
FlowmasterMufflers
07-17-2015 04:26 PM
FlowmasterMufflers
07-09-2015 12:35 PM
Nimoryan
07-05-2015 04:50 PM
Quick Reply: 2006 crew cab ls1 and t56 swap and build
