2006 Silverado 1500 SC Build
Old 07-01-2016, 12:58 PM
Schiavonske1013's Avatar
I did actually. Both shock mounts have been rewelded already. It's no joke up here.
Old 07-01-2016, 12:59 PM
Holey rust batman... that rearmost crossmember is almost gone at the attachment points...
I should cut that stuff off the frames I was going to scrap so I can sell it to you guys back there...
Looks like you already lost the rear shock mount at some point.
Honestly I'd heavily consider it. They are going to be gone in a couple years on mine.
Old 07-01-2016, 01:20 PM
Custm2500's Rude Friend
1FastBrick's Avatar
There is someone that makes a repair sections and oem style looking mounts too!
But if everything else around it is rusty how long is that going to last.
Look at this link you will see what I mean. He also sales the shock tabs separate.
Rear Fuel Tank Support Crossmember for Chevrolet Silverado or GMC Sierra 1500 | eBay
Old 07-01-2016, 01:34 PM
Yeah I have actually looked at the replacements, right now I'm just going to ride it out and keep an eye on it at this point.
Old 07-01-2016, 06:00 PM
Vortec350ss's Avatar
If that ever happens to me I am going to do a fuel cell in the back with a shock relocation and a single chromoly shock mount. Should drop a few lbs while I am at it. Luckilt mine is not that bad and I think it can be saved.
Old 07-01-2016, 09:46 PM
Ultimately mine isn't nearly as bad as it looks, I may end up doing one of the crossmembers, but the gas tank support is solid.
Old 07-01-2016, 11:30 PM
How is the under side of the bed and body?
Old 07-02-2016, 12:53 AM
8 Second Truck Club
Blown06's Avatar
...why I won't buy a ride from the Northeast.
Old 07-02-2016, 05:45 AM
Bed and fenders are surprisingly good considering it's a z71 and has the fender flares. Rockers aren't pretty but that's not surprising.
Old 07-02-2016, 08:23 PM
So where do you guys have your heat exchanger tank/pump? I mounted the tank to the relay box and was going to try mounting the pump in the tvs location since I technically have that pump and that reservoir, but the pump outlet seems to come out directly behind the headlight mounting panel.
Quick Reply: 2006 Silverado 1500 SC Build
