2012 RCSB 416ci TVS2300
#91
i have an idea of getting my IAT's down before i add meth, taking the idea from the killer chiller and its been proven by a friend of mine who tried it told me that the IAT with a tvs2300 was 2-4 degrees lower then ambient while cruising.. after the maggie reservoir the water goes through a box which is cooled by the A/C line which will be extended, has no effect what so ever on the A/C performance.. the box will have a cooler like fin tube inside which will be the extension of the A/C line which will be inside the box cooling the water in the reservoir tank
#93
LOL i couldn't even hold the phone properly 100F outside , 10# of boost running 19-20 degrees timing.. 93 octane.. running meth soon
I need to relocate my transmission cooler from here, it takes forever to cool down i need something with a fan which will fit there, cause i have no space behind the grill because of the heat exchanger
[IMG][/IMG]
#97
200-205 after a wot run
185 in cruise.
Need a new cooler where should i fit mine i have the heat exchanger behind the grille now probably get a smaller one and fit it behind the heat exchanger
185 in cruise.
