370 build FINALLY getting started
Old 07-08-2008, 10:11 AM
  #101
Hawk179's Avatar
Originally Posted by Wilde Racing
And if you play nice, I'll tell you my secret
hehehehehe. Considering how long I was playing with STS kits, I might have a few more on you.
R
Old 07-08-2008, 10:24 AM
  #102
How do I change this text
Wilde Racing's Avatar
R
Seams how you are trying to make a living at this sort of stuff, I'd hope so....
Cam specs are one of the fallowing.....
215 215 115
220 220 116
210 206 118
218 214 114
232 226 116
Old 07-08-2008, 10:27 AM
  #103
FormerVendor
Derek @ EDO's Avatar
215 215 115
220 220 116
210 206 118
218 214 114
232 226 116
232 226 116
Old 07-08-2008, 10:29 AM
  #104
Hawk179's Avatar
215 215 115
220 220 116
210 206 118
218 214 114
232 226 116
I have pretty much used close to all of those already. I can tell you the pros and cons of each. The one thing I will tell you that any limitation in each camshaft or short goings is not because of the cam, its because of the location of the turbo. This is the hard part with your kit. Every cam you pick will actually work different than it would if the turbo was up front where the heat and flow is better. Dont even bother going for the bigger of the cams on your list either.
Rick
PS. Giving generic numbers @.050 like you did with nothing else about the lobe, type, lift, seat, advance, timing events, ect, does nothing for helping with cam selection.
Old 07-08-2008, 12:17 PM
  #105
I actually picked my cam by IVO, IVC, EVO, EVC and let the specs fall where-ever....
No advance ground into the cam....
Old 07-12-2008, 04:07 AM
  #106
9 Second Truck Club
stock48's Avatar
Anymore progress?
Old 07-17-2008, 01:51 AM
  #107
Originally Posted by stock48
Anymore progress?
Yes, tonight was night one of the "get my f-ing truck back together" week.
I finished installing the pistons, got the cam and chain in. Tommarrow I hope to have a head or two on....
I had to use a hammer to get the cam to go in this way.......
Old 07-17-2008, 02:27 AM
  #108
9 Second Truck Club
stock48's Avatar
Looks good! Next week mine starts.
Old 07-17-2008, 02:30 AM
  #109
9 Second Truck Club
stock48's Avatar
Looks like your quench is a little tight
Old 07-17-2008, 02:47 AM
  #110
naw. I just hope the rings don't get cought going back into the bores....
Quick Reply: 370 build FINALLY getting started
