370 build FINALLY getting started
#153
How do I change this text
We ran the tubes in the Motorola cup cars because if we put the back plug types in the #7 cylinder would have problems. It seemed to me with the testing we did that air pockets formed in the back of the head from the coolant boiling causing the engine to detonate on the back cylinders. Normally #7 would eat the piston or break the rod and #8 would show signs of trouble. These are just guesses on my part based on what the parts looked like broken!
Kurt
Kurt
#157
Well not much to report for tonight. I got the water pump on, all the rockers, exhaust manifolds, and knock sensors in. All I need to do to the block is Flywheel, oil sensor, and prime... I did get the reverse apply pin in the 4l80, so the trans is ready to go....
#158
The Engine Runs!!!!
Well, the trans is in the engine is in. I fired her up for a few seconds last night, just need to tie up all the loose ends and fix my shift cable..
why did you remove the steam tubes? How do you get the air pockets out of the heads?
