370 build FINALLY getting started
#81
9 Second Truck Club
Im at .004'' with the low expansion Mahle's, they recommend .003''. Plan was to try it tight to see what I can get away with, but with this screwed up economy I don't have the funds to experiment right now. I think we are better off a little on the loose side rather than tight, especially if towing with boost. Rather only make it 7,000 miles than 7.
#83
9 Second Truck Club
Because the 2618 alloy grows more. I wanted a piston that is light, and tight, it gets cold hear in Co. I had planned on running the tight .003'' clearance, but since the money tree is drying up I chickend out. Another reason an alloy that grows a lot will just keep growing if you get in a situation. I figure if the stock cast pistons can take 700+RWHP the 4032 should be good for 1000
#84
Thats also why a Mahle piston requires less as well, it does not grow like a Diamond or others.
R
#85
Loose is fast....kinda like a good women.
R
#90
