408ci-LS3-th400-KBracing gt91-RCSB *BUILD*
#82
Location: Where our street cars are faster than your racecars..Mississippi
mounted the inter-cooler behind the grill...
it has plenty of room for AC condenser and all behind it... only thing you will have to do is mount the trans cooler .. i am putting a rather large trans cooler with its own fan in my truck so i was not worried about it yet... i will make it fir once the time comes to start on it...
#84
So, you cut the hood latch support and welded it to the IC?
I like the way you welded the elbows to the inlet/outlet but it might get difficult to hook couplers to it at the sides of the radiator.
Can this setup be done for DD keeping the A/C and trans coolers in place on a 2003 Silverado. Space seem plenty on my 03 Chevy Silverado truck.
#86
GFYS and STFU
Here's the charge pipe that connects to the I/C outlet, you can see the coupler on the end of it...
And here's the piece of pipe that runs between the turbo outlet and the I/C inlet (very bottom of picture), again you can see the coupler, all you need to do is slip it on and tighten down on the hose clamps...
2003 is a different configuration from the 99-02 from what I understand or at least the grill affords more room so I can't answer that question. But with enough ingenuity, anything is possible.
#87
It should fir. If not, the trans cooler can be relocated or replaced with different type with it's on cooler fan if it's not facing air.
#88
Well... I havent done mutch but....
Replaced the 24x11x3 intercooler with a 31x12x4
Ordered a Magnafuel 4303 and an Aeromotive FPR
Got my 9" narrowed and my strange 31 spline axles
Bought a stepside bed (think it will look sweet with my 390/45-15 drag radials)
I hope to have more progress pics this weekend
