408ci-LS3-th400-KBracing gt91-RCSB *BUILD*
Old 02-12-2011, 12:11 AM
  #61
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
Originally Posted by LQ4JOSE
denali_on_26's..... Hats off to you i wisH i Had tHe patience to collect parts for a build for tHat long
Thank you man...
There has been alot of "why the f am I even doing this...i should just sell it all"
But finally it is starting to be worth it
Old 02-12-2011, 12:51 AM
  #62
Denali08's Avatar
How much boost do you plan on running?
Those ls3 heads are the same as l92 heads, right?
I read that l92 heads are not good for high boost.
Old 02-12-2011, 09:58 AM
  #63
They are no different than the 317 heads as far as boost... Everyone is screaming they wont work with boost but look how many is making GOOD power with them with FI
Plus I can run less boost and make same power compared to 317 heads... I want to see how far I can take OEM UNTOUCHED heads and intake...so I choose these to work with
Old 02-12-2011, 10:13 AM
  #64
I have a gauge for that
Atomic's Avatar
Most guys start having problems with lifting oem heads around the 15psi mark. Head studs keep them down to 20ish I think.
Old 02-12-2011, 08:28 PM
  #65
1989k1500's Avatar
SilveradoL33 ran 19psi in his all the time and it never had a problem. And another friend of mine put 23 into his stock LQ9 and it just seeped a little.
Old 02-13-2011, 07:57 PM
  #66
i know ALOT of people have wondered and have asked if you could put the IC behind the grill of a 99-02 truck... i know thats what i would rather have honestly... so i think i may try it... seems pretty easy even with the 34" radiator and using KBracing cold pipes as well just adding longer couplers in 3 spots and cutting 2 pipes shorter... i hope it works if not i am going to be **** out of luck...lol
Old 02-14-2011, 06:26 PM
  #67
Old 02-14-2011, 06:39 PM
  #68
Atomic's Avatar
I like that setup a lot
Old 02-14-2011, 08:17 PM
  #69
GFYS and STFU
Spoolin's Avatar
It'll work, looks like mine kinda!!
what size piping is going into and out of the I/C?
Old 02-14-2011, 08:38 PM
  #70
kazfan30's Avatar
I am happy to see that thing coming along, Thomas is legit and has really worked hard on this setup, I really hope it turns out great and flies man... Gots Faith in Youz
Quick Reply: 408ci-LS3-th400-KBracing gt91-RCSB *BUILD*
