5.3 HB build
Old 08-29-2013 | 12:47 PM
dvdswan's Avatar
Default 5.3 HB build
so i thought I would post the build I'm doing. I'm well into it so for the most part its going to be a picture show.
I was bored one weekend and surfin' the net and came across a CL add that I thought was a decent deal for me. I wasn't looking for anything in particular in a sense. 2003 4WD Tahoe drivetrain complete with wiring and PCM. 5.3L, 4L60E, NP246
call the yard up and they gave me the speill so I said I'd take it.
I new it would be cool to have touch 4WD but didn't want it so I picked up NP241C
and started to tear down the 5.3L
I'm not a transmission person and don't have the special tools so I had a local shop rebuilt the trans. they had 4l70e 5 gear planetaries installed for the low/reverse and OD gears.
I did install new bearings, seals, and SYE for the 241C
took the truck down and had the AC evacuated then washed to get ready for removal.
and yanked out.
fitted the block with empty transmission.
clearnace for the radiator
and that's not going to work
motor mounts comprised of 2 kits from TransDapt
started to build the engine and then a delivery came from the j/y
finished the rebuild on the engine
Old 08-29-2013 | 12:59 PM
dvdswan's Avatar
did some checking on the fitment again.
and at this point I knew some mods to the crossover hoop were required or a lower intake is needed.
truck AC would need to cut the frame, time for some thinking.
PS fits fine
but the alternator was telling me that a portion of the hood would need modification
removed the bed and fenders, doors to remove the cab
refit the engine, trans, t/case to make the rear mount
and I just wasn't happy with the angle of the front output
started fitting the new cab
and a little more trimming is needed
Old 08-29-2013 | 01:12 PM
dvdswan's Avatar
trimmed the cab to fit the frame and fuel tank
added the pathfinder tank to the frame
enclosed the cab
and sealed it
and lizard skinned it
transmission crossmember
not happy with the headers
BigDaddy0381's Avatar
That is a neat build.
Old 08-29-2013 | 01:23 PM
dvdswan's Avatar
trans mount finished
bracket for the fuel tank selector valve
and tried the stock exhaust manifolds, they fit better just not what I needed.
started to fit the bed, this is a bed I had around that was shortened 8" to fit pathfinder quarter panels to it.
made some heat shields for the coilovers
XMAS in May!!!!
new serp setup
and exhaust pieces
so i started that
and a buddy TIG'd them up
Old 08-29-2013 | 01:35 PM
dvdswan's Avatar
started the driver side
back to working on the bed to fit the cab, 14" off the front of the bed
new distance for the radiator, the corvette accessory setup is 1-9/16" shorter (closer to the block) than the truck acc. setup
and high mount AC, need to loose the battery tray
still needs some trimming
had to notch for the 4WD shifter
fit the trans shifter too
finished tacking up the exhaust
trans cooler came... hoping it was the radiator
but it came the next day
and its going to be tight
Old 08-29-2013 | 01:43 PM
dvdswan's Avatar
cooling fans came
thats a tight fit too
trimmed the front core support for the radiator and made brackets for it
picked up a LS1 intake for fitment, its low but I'm not liking the clearance to the radiator for the air cleaner tube.
finished tacking the pass side bed and alignment for the tailgate which needs to be narrowed 2"
and tacked in the front bed mounts
to be continued...
Old 08-31-2013 | 08:59 PM
dvdswan's Avatar
so today I work more on the bed, did some trimming for the spare tank filler neck hose and tacked in a wheel well from my old bed. did some more fitting for the taillight and the tailgate. I think there is a plactic piece that the Pathys have the goes next to the taillight but don't remember. I have about a 1/8" gap top and bottom between the sheet metal but the taillight gap is about a 1/4". More thinking here. I also went to the junkyard looking to stuff and found a 85 Pontaic GTA, hood louvres! sweet and in great shape too. (there's another GTA hood there in great shape too, I'm might pick that one up too)
yep, love the pathy taillight over the truck taillight
now I have to decide how I'm going to place them. these are true working louvres, so engine temps will be cooler for wheeling.
Old 08-31-2013 | 09:26 PM
TIM Z's Avatar
11 sec. Truck Mod
Wow man I appreciate all your hard work/fab ! Gonna be a fun truck when your done . Nothing better than an LSx engine under the hood !
Old 09-01-2013 | 06:57 PM
dvdswan's Avatar
thanks. I'm thinking it will be... tons of fun.
did some work on the dr. side bed and some more thinking on the louvres.
the long slats are at the slight slope of the hood to allow the air to flow into the engine compartment.
and these would be with the old style hood with the 3 slots in the front and made so that air would flow through them.
Quick Reply: 5.3 HB build
