5.3 HB build
so today, went back the j/y and picked up the GTA hood so I can cut out the louver openings. 25 bucks beats the 100-200 on e-bay just for the louvers. lol then stopped by the local chevy dealer to pick up parts I ordered and drool over a SS Camaro, I'd rather have a COPO Camaro though. lol then cut off the driver side taillight assembly and tacked on the pathy 1/4 panel, looks like a unibody lol
I'm going to need some trimming on the pass. side cover because of the high mount AC, but I was completely surprised that the fit under the crossover tube.
so today I think a lot got accomplished. more little stuff, but a lot of little stuff. 1st, reverified the thermostat housing to the lower radiator.
the upper and lower hose pipes will be cut and have 90* pipes installed. the veiw looking down, you can see how the upper hose will be with a 90* in the hose going to the water pump, the side view you can see the hose will have about a 30* bend to the lower hose pipe.
I made a cutout for the heater hoses to go by the AC compressor.
I also removed the strip on the pass side to weld up the front inner bed side
my friend evened the gap on the driver side bed side for a clean fit, then installed it. I prepped the tailgate bracket so I can possibly get that done tomorrow and still need to fit the front of the bed side but its on.
so today I worked more on the bed. got the dr. side taillight assembly welded in. tailgate is now going to be right around 50", inside opening is 48-1/4" and outside opening is 50-1/4". tailgate is currently 54-1/4" so 4" must go bye bye. I tacked the inside front of the bed, the wheel well opening is also tacked in. I had to trim some piece on the tailgate support so the lights fit in perfect. I will add the metal back in but it will be straight instead of bending in towards the taillight assembly. I also cutout the louver openings on the GTA hood, then put tape lines where I am thinking of cutting out for the rear bumper.
thanks guys, I certainly don't plan on denting the truck. in all my 20 some yrs of offroading I haven't done much damage to the vehicles I've had. I'm more out for the scenery and the need to get away from stupid people.
