5.3l to a wild 383 stroker
If you are going to spend that much money on a 5.3L, not sure why you wouldn't just start with a 6.0L like Dirttrackracer stated. You might spend a bit more for the block itself but you are buying all the same parts that would make a 408. No replacement for displacement.
I built one. I have over 10k miles on it and never a single hint of overheating, even when towing 7000lbs in the summer heat. The engine has been nothing short of perfect except for a sticky injector recently (hardly the engine's fault). I'm running 11psi of boost and making well over 500 reliable wheel horsepower and similar torque. I would do it all over again. Here's my build thread:
https://www.performancetrucks.net/fo...tblock-478266/
I've gained a lot more HP since I ended this thread. A bigger blower would likely see almost 600rwhp. Ahh, some day...
In my opinion, all the myths pertaining to boring out the 5.3 are pure bunk.
Thanks...Man I cant keep a strait face with that dang avi you have.. MY GOD...I hope if and when I get a decent motor going in this sled I hope it will have the same size stones as your pet chimp....BAHAHA
So you bored the 5.3 out to a 6.0/6.2? Did you have to go with a larger cooling system? Just wondering. thanks
Sorry....I will not be around Fri....but want to thank all of you for your replies and will be back Sat. to see what kind of havoc i can wreck on here. Thanks again for all of yalls input and sharing your knowledge. Its well appreciated.
