6.0 Stick Shift Tahoe (NV4500)
Old 05-13-2020, 03:21 PM
  #171
Custm2500's Rude Friend
1FastBrick's Avatar
Talking
Originally Posted by dantheman1540
Only both times.
I see you changed your location as well...
Old 05-13-2020, 03:22 PM
  #172
dantheman1540's Avatar
I changed it all just for you
Old 05-14-2020, 07:37 PM
  #173
2002_Z28_Six_Speed's Avatar
What the hell is this cul-de-sac that you and steve unleash hell in all the time. LOL place is probably littered with metal by now. Time to call the street sweeper!
Old 05-14-2020, 07:45 PM
  #174
It's a side street just outside of Mexico city. La Policia don't mind at all.
Have a good video idea brewing after I "Florida Proof" the current problem area.
Old 05-17-2020, 10:14 AM
  #175
The 1410 yoke from Dennys Drive shaft appears to be moderately more clutch dump resistant.
Also gave the Tahoe is quarterly wash and wax.
Bluecollar Hotrods (05-25-2020)
Old 05-18-2020, 08:21 PM
  #176
Drive shaft is off to get yoked and my parts are back from bedazzling. This stuff is just mesmerizing to look at.
Old 05-19-2020, 12:19 AM
  #177
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
Stock sway bar?
Old 05-19-2020, 06:05 AM
  #178
Originally Posted by arthursc2
Stock sway bar?
Nope that thing is in the scrap heap, this is a Hellwig bar.
arthursc2 (05-19-2020)
Old 05-22-2020, 08:34 AM
  #179
Rear end is back together and bedazzled now. Also gave it the quarterly wash and wax.
The clearance between the QA1 panhard bar and the PML slim cover is about a finger which worked out perfect. Still gotta solve some leaks in the bag setup. All the supplied barb fittings are pretty useless and the spring clamps are so loose they just go where they want so I have some better fittings from airlift performance coming. I want it to hold air for more than a day because on a hard launch or gear change the axle rams the exhaust into the frame and sounds terrible. I might be able to massage the frame cross member a little but I don't think it will be enough. If I can't get the bags to hold air then Ill just get a longer bump stop and lose some up travel which is fine I guess.
Old 05-22-2020, 11:36 AM
  #180
makes children cry
_zebra's Avatar
looks like that 'hoe just got a lap dance
tjmath (05-25-2020)
Quick Reply: 6.0 Stick Shift Tahoe (NV4500)
