6.0 Stick Shift Tahoe (NV4500)
#21
Couldn't take the factory halogen headlamps anymore so I did a projector retrofit with Morimoto Mini H1 projectors and Morimoto 35w/4500k HIDs. These headlights are super small and hard to retrofit so a company called Lightwerkz sells brackets to convert some cheap Depo knock off retrofit headlamps to quality Morimoto projectors. It truly is as simple as unscrew the only projectors off the back, bolt the brackets to the Morimoto projector and screw them both in place on the old ones.
I was skeptical at first but they came out great and the performance is better than a 2019 Tahoe headlight.
Also had a local detailer buff and wax the 15 year old paint back to life.
#23
Custm2500's Rude Friend
I thought someone may have returned them to the dealer prior to me getting them since the were Not opened in front of me. Apparently the parts guy opened them to make sure they weren't damaged. He ordered another set and let me open them up when they came in... Same...
I don't need to pay GM $150 for a tail lamp that I can get for $50 on the internet...
The tail lights are decent But the headlamps and turn signal lamps Suck!!! The lenses yellow after a few months and the little peanut bulbs don't fit in the corner. I had to take the last set USA made lights I bought off my VHO truck before I sold it.
#25
Sad thing is I ordered new GM Tail lights at the dealer... Guess what was in the GM Box that now says made in china... DEPO...
#27
I was surprised when I contacted Lightwerkz about having them build me a custom retrofit headlight they said they use Depot lenses and housing for older GM stuff.
P.S. Let me clear it up and say that I wasn't looking to get demon eyes, color changing halos or anything uhhh............. Flashy...... Just a simple clean projector.
#28
Do you have a prefered aftermarket headlight brand?
The DEPO was decent fit in the rear and I would probably use those again. But Fronts, Seems like nothing fits or last the same as OEM.
My buddy has Vision on his GMC. The Lenses are very clear but the plastic where it mounts is flimsy and they tend to flex there where as the OEM's are rigid in this area.
#30
I've actually never heard of Xenarc X2020s. I guess I'm late to the game.
If I didn't hate small detailed work so much Id get some OEM lights pull the lenses to refurb them and do a full retrofit but I despise projects like that.
I much prefer to hit things with hammers
