6.0 Stick Shift Tahoe (NV4500)
#641
10 Second Club
I'm not super familiar with the NV4500, does yours have the 3.44 or 3.04 2nd gear ratio? Either way, should be enough even with 3.42s - unless you have some stupid cam that doesn't turn on until 4000 RPM. I'm sure you already know... vehicle weight and heavy *** wheel and tire combo don't help. If you can just practice and consistently get into the 2.2-2.3 sixty foot range in street trim - it will be about a full second faster than the times with 3+ second sixty foot times. What do you feel that it makes for power?
#642
I think it makes between 350-375whp.
watching the videos it doesn’t look to be transferring weight well at all, I think I need to put a bunch of effort into shock tuning.
#643
makes children cry
from what i understand (without having a lot of experience in that area), pressure would depend on your tire's load capability, sidewall strength, & your weight (among other factors).
i honestly couldn't give you an accurate estimate, but normal street pressure is often a little high, and 10lb low is often too far. I'd just play with it in the mid 20s & go from there with getting the launch more systematic.
as for 2nd gear: think about that a second. roughly equivalent to a 4L60... with 33s... and 3.42 gears... and essentially a torque converter that goes straight into lock-up. how many threads have you read where guys complain about how doggy their stock truck's launch is?
dantheman1540 (01-21-2022)
#644
So true however, wouldn’t a cure for that in an auto be to get a converter that allows them to launch harder off the line at a higher rpm? Meaning I could potentially just slip/dump the clutch at a higher rpm in second and negate the negatives of the off line sluggishness? Or is it just never gonna hook and book in second and doomed to bog every time?
#645
10 Second Club
2nd gear is 3.04 so almost the same as a 4l60E first gear which isn’t a bad thing. The cam feels good down low but I can definitely feel it come in stronger around 2,800rpm. Is a 2.3 60’ good? I have no experience racing and figured a 1.9 should be doable, I managed a 2.3 on my best run leaving at 2k in first with a small amount of spin.
Again, JMHO - without a crazy launch, 350-375 RW should be capable of mid 14s - even at 5500lbs. In my own personal experience, 1000 lbs lighter and 100 less RWHP was good for 14.5-14.6 with 2.2x sixty foot times.
#646
2.3 isn't "good" per se~, but beats the crap out of a 3.xxx short time. My humble opinion: going to need at least 4.10s with the vehicle weight, tire height/weight, and that camshaft. With a 33" tall tire and a .7 something OD - it shouldn't be bad on the highway. I have 4.10s, .75 OD ratio of the 80E and 30" tall tires on my truck. It's fine on the highway, I'm not trying to drive 80+ MPH. Just remember HP is king because TQ says it can be. (An old timer saying for HP is a biproduct of TQ)
If I ever do 4.10s it will be an H2 gear set and E locker it’s by far the most affordable option.
#647
After crunching the numbers some more I think I can hit low 12s if I toss on the ported 243s I have on the shelf so…… Gaskets are ordered and I think I’ll just let the mystery lifters (possibly ls7s) hang out awhile longer, they quit making noise when I switched back to 5-30 with a qt of Lucas.
JK about hitting 12s but I am gonna throw them on. Should I get new seats and seals or use the ones from the current 862s that have 20k on them?
dantheman1540 (01-22-2022)
#649
makes children cry
after having 4.30s & 33s with that same transmission and a cammed 5.3, i'd keep the 3.42s and just deal with the slight lack of acceleration rather than swap to 4.11s & lose a gear.
if this was a race truck, i'd sing a different tune... but it ain't.
and so you plan to drop compression with them 243s? why for?
#650
I figured you’d agree on the gears I actually love how it drives on the street with the 3.42s and 33s.
They are milled with 63cc chambers and I calculate 10.07:1 with LS9 gaskets. Currently it has 10.39:1 with the 862s is .32 compression gonna be noticeable at all? I could run LQ4 gaskets and get 10.16 or wait for some .041 cometics and get 10.4:1.
I was considering the ls9 gaskets in consideration for future boost although that will be awhile.
