6.0 Stick Shift Tahoe (NV4500)
Old 01-28-2022, 04:52 PM
  #671
makes children cry
_zebra's Avatar
Originally Posted by dantheman1540
That looks beefy! Is messaging him the only way to order it? I didn't see any engine stuff on RKTs site.
what? you can't message him as a non-member of vetteforum?
Bret: 972-741-7457, and he'll shoot straight with you. tell him i said hi.
Old 01-28-2022, 07:25 PM
  #672
dantheman1540's Avatar
Bret: , and he'll shoot straight with you. tell him i said hi.
Sweet I will call him Monday! I did find his email as well too.
Old 01-28-2022, 07:28 PM
  #673
Originally Posted by wretched73
Gotcha, it’s ordered thank you!
Originally Posted by RedXray
That's the after photo... not a contortionist so I opted to drop the pan, 2wd is pretty easy. 4wd I don't know the procedure.
Modified Harbor Freight 3 jaw puller with 2 large hose clamps to keep jaws on the OEM crank gear. The clamp helps when you don't have a 3rd hand to secure the jaws. Rollmaster crank gear installed by hand.
Pan off
Pan clean with new gasket in place. I used a little RTV on the corners between the new gasket and the pan. The nuts and bolts (finger tight) were used to secure the gasket to the pan while the RTV setup so no slips during install. (zero leaks)
I think I kinda want to see what the inside of the pan looks like so I guess I’ll man up and pull it all.
Old 02-01-2022, 10:56 AM
  #674
LS1Tech Sponsor
Summitracing's Avatar
That's the page I've been using to make my decision, great info, and thank you!
Awesome! We're glad that you had already found the quench article and found it helpful!
dantheman1540 (02-07-2022)
Old 02-07-2022, 06:48 AM
  #675
Got most of the truck torn down and then ran into some minor issues. First off I broke both spring compressor tools I had, I guess dual springs are pretty tough and these are garbage. Then I was unable to remove the ARP crank bolt which I installed two years ago. I think when I installed it I used my impact but had the front end apart so I got a straight shot on it, now I don't want to pull it apart but a wobble and extension is robbing too much power from the Milwaukee.
I did port the outlet on the M295 pump I bought for $63 and checked the spring which is blue so it should make 60psi which should be sufficient.
Also dropped the pan and it looks fantastic to me! I didn't drop the windage tray yet and I didn't check deck height because I ran out of time but I thought the pistons looked alright with not to much carbon build up.
The following 2 users liked this post by dantheman1540:
RedXray (02-07-2022), wretched73 (02-07-2022)
Old 02-07-2022, 10:28 PM
  #676
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Hit the ARP crank bolt with some heat then rat-a-tat with the impact.
dantheman1540 (02-08-2022)
Old 02-08-2022, 11:41 AM
  #677
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
When your motor looks like @RedXray 's you can say "it looks fantastic inside"
Your's... is not fantastic
Old 02-08-2022, 02:14 PM
  #678
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
When Red drops his oil pan it is polished and the inside and all the oil is neatly packaged in a box for him to take out
Old 02-08-2022, 04:10 PM
  #679
Seeing nothing other than oil inside a mystery motor oil pan is pretty dang fantastic to me! I expected to see at least some sludge in there.
Heat the bolt I shall.
Old 02-10-2022, 10:36 AM
  #680
BigKID's Avatar
Be mindful with the heat or you will damage the elastomer in the dampener.
Is the broken spring tool aluminum? With the moment from the ratchet, a better design would incorporate a hardened steel bushing there.
I have had good luck with the two-spring tool that bolts to the pedestal and has a hardened stud and nut to compress the springs. Just have to be sure and keep the stud lubed and retaining bolts on the pedestals run down snug.
Quick Reply: 6.0 Stick Shift Tahoe (NV4500)
