6.0 Turbo build
#244
Ended up getting the first set, the boots look shorter than that the second set, hopefully they wont touch. This must have happened because when the manifold was machined it was not perfectly level and the angle its on now makes it touch the stock wires....
#246
I know trick's manifolds look nice but then I have to redo my whole hotside or buy a trick hotside. Worst thing that happens is the flange gets cut off and a 1/2" thick ones gets welded on. I dont see why that wouldnt work
#247
I have a gauge for that
By cast I also mean the stock truck ones, but yes that means redoing your pipes either way. Im not saying you have to, im just saying if you start running into warping and cracking issues (at the welds) you might have gotten your life use out of what you have. A thicker flange may not help you. Hot metal wants to grow, and stainless grows a lot more than mild.
#248
So I made a stupid mistake and ordered car wires. But the wires after one trip to vermont arent toasted so Im just gonna say **** it and go on friday on the last street night and run it. Now im tore between ordering the right set of taylor wires that I could possibly cook or getting the accel ceramic booted ones that stand up to 2000 degrees. Im kind of leaning toward those and never worrying about that again...
