6.0 Turbo build
Old 09-23-2016, 08:58 PM
  #291
GM1697's Avatar
Originally Posted by GRRR65GTO
No I havent bought it yet, Ive been really thinking about it...
pull the trigger
Old 09-24-2016, 02:06 AM
  #292
8 Second Truck Club
Blown06's Avatar
Solid motor mounts really isn't a big deal. You'll hardly notice any extra vibration.
A word of caution though.....if you do decide to go solid motor mounts, whatever else you do, make sure you still use a rubber rear trans mount. Some use a poly mount, but I highly advise against it. Rubber only!
Old 09-27-2016, 08:35 AM
  #293
GRRR65GTO's Avatar
Thanks for the info guys, maybe eventually Ill get solid motor mounts but well see what happens for now once I get everything fixed and back together. I sent the manifold out to Kyle yesterday to get a new flange put on so shes dead in the water for a while
Old 09-28-2016, 12:56 AM
  #294
GM1697's Avatar
The flange was that messed up again?? already??
Old 09-28-2016, 02:17 PM
  #295
idahoblkss's Avatar
im not understanding what the advantages are of running solid motor mounts?? why would one do this?
Old 09-28-2016, 03:00 PM
  #296
I have a gauge for that
Atomic's Avatar
To stop the engine from moving under load. With worn out mounts the movement can be several inches as it tries to rotate.
Old 09-29-2016, 01:15 AM
  #297
8 Second Truck Club
Blown06's Avatar
There is also fore and aft movement as well, hence the need for limiters when doing a motor plate/mid plate set up.
Old 10-19-2016, 10:03 PM
  #298
GRRR65GTO's Avatar
Manifold update
Sent it to kyle for a new flange, luckily hes a great guy and deals with me wrecking his work... he had to cut the manifold in half to relieve the stress in it, whoops...
Right now its a ceramic coating shop so I never have to deal with header wrap again, and for $100 I was stupid not to do it before
Next friday is Diesel night a NED and I was hoping to run but time will tell if the truck will be together or not. I got some 305/65/18s on it now so hopefully I can launch better in 2wd and hopefully the bigger rubber wont kill my top end too much
Old 10-19-2016, 10:15 PM
  #299
GM1697's Avatar
Manifold update
Goodluck, I hope you make it up there next weekend. Rob should be out there sunday night if you dont make it friday and still want to go.
Old 10-19-2016, 11:34 PM
  #300
Vortec350ss's Avatar
I'll be up there this Sunday morning and I'm staying as far away as I can from diesel night. It's such a shitshow...
Quick Reply: 6.0 Turbo build
