6.0 upgrade with a few extras...
Ok how much should we mill the stock heads? I dont know much about heads. What compression should i go for? planning on running a 100-150 shot
I would just shoot for 10.-1 compression if you're just milling the heads. you would need to mill the heads about .050 to take off the 6cc's to get down to the 66cc you would need for that. thats a rough measurement, but rule of thumb is .005 takes off 1cc. if you have a good machine shop just tell them you need a 66cc chamber and they should mill them to get the right size. you could also go with a .040 gasket and you would only need a 68cc chamber.
I have read you don't want to take off more then .050, but that might have only been for intake fitment. also you will want to check ptv clearance with milling them down so much. if its possible to mill them farther a .040 gasket and 64cc chamber will give you 10.5:1, if you use stock gaskets you need a 62cc chamber, I would shy away from trying to mill them that much though.
