67 chevy build
#22
The biggest issues with a 2 link are pinion angle, lack of flex points, and no backups for power handling.
As your suspension moves the pinion angle changes drastically do to basically being on the end of a stick. Hold a yard stick out and move it 3-4 inches up and down and see how much the tip changes angle. Again with springs not as bad as with a bagged set up but it still isn't ideal because it can cause drive line binding.
Only having two points that have any pivot and flex makes any thing besides both tires moving vertically together a bind on the two pivot points.
Finally Power handling is obvious. There are guys putting good amounts of power down but I wouldn't consider it ideal. You have two bolts, and two welded or u-bolted perches holding you axle on. If you notice this set up was factory back when 100 factory hp was allot.
#23
And besides, this is Aarons build thread, not a truck arms suck debate!
#24
Well he asked for information.
Nascar also isn't launching from a stop and putting down event 800hp from a roll is nothing like launching a heavy truck with 300-500hp. They are on a smooth surface not going over curbs, pot holes, and everything else on a normal daily drive. They are built to drive a banked track for a few hundred miles. Along with all of that they are looked over and rebuilt many times over a season so if anything gets bent or bushing are worn they are replace long before they would be noticed on a typical daily driver.
It is his build thread of his very nice truck but the reason for going on these forums is to learn therefore debates aren't a bad thing.
#25
Why are you still shitting on this thread? Its a static setup, its the stock suspension, its in a play truck. Just let it go man. All I seem to see you do on here is argue with people who know more about the topic than you. Stop attempting to be smarter than everyone and you wont look like such an ***.
This thing will be sweet with a turbo LS in it!!
#29
I saw somewhere that the older trucks with the factory 2-Link they make the arms somewhat flexible to aid in articulation. Makes sence to help keep the tires on the ground.
