71 c10 lwb turbo 5.3
#22
got intercooler pipeing in
got other side of bed primed and back
primed underside of cab and the back of it
started redoing wiring harness
removed wires not needed was alot
extra pins removed from ecm
how it looks now every wire in harness will be made longer or shorter to route wires where i want them
still have some body work to do on bed but easier to see when its one color
#24
its not as bad as it looks i need to determine where coils will be for the wiring to them and trying to decide finding a bulkhead connector and put ecu in cab or mount to frame under cab and will be going to local pull a part to get injector pigtails and iat pigtail maybe few other things depending what catches my eye
#26
got new injectors in along with new pigtails for them and turned them to inside to clean up the wiring because coil packs will not be on valve covers and alt,throttle body wiring will be under intake
started to fit hydro boost only had to dril couple holes and will have to extend the rod that connects to brake pedal
started to rattle can firewall but ran out of paint
#29
finished up firewall and painted back of cab and front of bed with rattle can so when new mounts come in i can put cab back on. paint is valspar low gloss black tractor paint from tractor supply back of cab still wet so looks more glossy than it is
got new 3k stall transmission specialties converter in
