71 c10 lwb turbo 5.3
#35
it been a while had lots going on and no time to do stuff to truck but did finally get the cab on, front fenders and hood mocked up to get idea of what its going to look like. this is sitting at ride height
droped
droped
#36
got some exhaust work done last couple days cut and welded stock manifolds they are cast but didn't heat or anything and welded good with no cracks now i just need to get some bends to finish it up then take the time to smooth everything out before i have them coated
#37
Sick build! My first truck was a clean 69 rclb...Curious why you diddn't get the matching flanges for the exhaust mani's? I have some cast iron welding rod that requires pre-heating that I use sometimes...As otheres have said I admire your work ethic
#38
i didn't like the angle that the manifolds exited as you can see the pass side is almost straight out instead of pointed up so this way all i need is one 90 degree and two 45s to get pass side to turbo flange. also as for welding the manifold all i used was 3/32 7018 rod with no heating or slow cooling just welded and it didnt crack these where just a test and if it didnt work i had another set i was going to get flanges for them
