72 4x4 MP T70 turbo 5.3 and bags buildup
Old 11-12-2007, 06:19 AM
  #91
tdrumm's Avatar
Wow, I have no idea how I missed this thread, but what an awesome project and you've got some amazing fab skills. Everything looks beautiful. Looking forward to more updates.
Old 11-12-2007, 09:08 AM
  #92
High on diesel fumes
thunder550's Avatar
Originally Posted by kbracing96
I think I see a loose wire. Might want to check that out.
Old 11-12-2007, 10:50 AM
  #93
kbracing96's Avatar
I just cut them all off
Old 11-12-2007, 02:21 PM
  #94
TURBHOE's Avatar
just wondering, if your doing a 2bar setup whats with the maf? are you going to try and use both?
Old 11-12-2007, 02:25 PM
  #95
thunder550's Avatar
2 bar MAF tune is possible. The 5.3 shouldn't exceed the limits of the MAF sensor with a little bit of boost. Anything over 10 psi or so might be questionable, but it should be fine under that.
Old 11-12-2007, 03:18 PM
  #96
TURBHOE's Avatar
ok i ask because when you go 2bar with hptuners i'mm 99% sure it turns off the maf.
Old 11-12-2007, 03:30 PM
  #97
thunder550's Avatar
The MAP sensor and the MAF sensor are not interrelated. Most people ditch the MAF and go with a speed density tune when they go up to a 2 bar MAP, but it's not necessary. The thing that "turns off" the MAF is either disconnecting it or setting the MAF fail frequency really low. You can always run MAP alone, MAF alone, or a combination of the two regardless of what type of MAP sensor is used.
Despite all of this, Kyle may just be using the MAF sensor for the embedded IAT sensor. Who knows, he's a crazy guy
Old 11-12-2007, 03:38 PM
  #98
TURBHOE's Avatar
yeah i went and did alittle searching over there. i guess most people just turn it off. now what about the whole thing where they say the maf takes over at 4000rpm. doe sit only take over till it gets maxed out? sorry not trying to jack the thread just wondering.
kbracing96 GREAT job. looks sweat.
Old 11-12-2007, 04:04 PM
  #99
thunder550's Avatar
There's a setting in the tune that identifies where the MAF takes over exclusively. From the factory it's 4000 RPM, but it's changeable. If the tune is set to run MAF only above a certain RPM and you exceed the limits of the MAF, the engine will not continue to compensate for increasing airflow. That =
Most who are making enough power to max out the MAF go SD. I'm guessing you can set the tune up to run off the MAF till a certain point then go to VE tables too. Not 100% on that, but the tunes are really flexible so I'm assuming it can be done.
Old 11-12-2007, 04:27 PM
  #100
kbracing96's Avatar
Ya, what Chris said, . Actually, I'm gonna keep the MAF for now and a 1 bar, cus I can't find the damn 2 bar MAP I bought for this thing almost a year ago, But will most likely still leave the MAF on there even after I put the 2 bar on. I have ran my truck both with and with out it and doesn't seem to make much difference to me, seem to compensate a little better with it and changing climates and altitude and since I wont always be around to adjust the tune from time to time I think it will be a better fit for pops. We are only gonna run around 6-8 psi of boost, so it shouldn't be maxing out the MAF.
Quick Reply: 72 4x4 MP T70 turbo 5.3 and bags buildup
