72 4x4 MP T70 turbo 5.3 and bags buildup
Old 11-12-2007, 04:41 PM
  #101
High on diesel fumes
thunder550's Avatar
Yeah, I've decided that closed loop is the way to go after driving all the way up there and having the tune lean out significantly. You gonna stick it in OL or CL?
Old 11-12-2007, 05:26 PM
  #102
SimpleManLance's Avatar
finally i found it again. ive been tring to find this thread with no luck for months.
awsome build up. im looking forward to the finished product.
Old 11-12-2007, 05:28 PM
  #103
kbracing96's Avatar
It will have a fairly conservative closed loop enabled tune with COS3 when I get all done with it.
Old 11-12-2007, 05:32 PM
  #104
thunder550's Avatar
Just curious, where do you have your throttle position set for enabling PE mode? I put mine at 28% all the way down the entire table, which is right about where I start to cross into boost at lower RPM. Higher RPM requires more throttle, but I rarely run in vacuum at high RPM so I didn't think it was a big deal.
Old 11-12-2007, 05:37 PM
  #105
kbracing96's Avatar
In the COS tunes, I don't use PE (it's set at 14.68 all the way down), I just use B3647 so any time it goes into boost, it richens up.
Old 11-12-2007, 05:59 PM
  #106
thunder550's Avatar
How did you get it to work? I'm using COS3 and whenever I go into CL it disables that table for me. I had to use the PE table to do my OL fueling.
Old 11-12-2007, 06:22 PM
  #107
kbracing96's Avatar
You actually only use a semi closed loop. You don't re-enable closed loop in the tune, you just put 14.68 in most of the B3647 table and it will use short term fuel trims to keep it at 14.68, then any time you get into a cell not commanding 14.68, like in the 80-100 kPa column, it goes into full open loop and fuels to what ever that cell is commanding.
Old 11-13-2007, 09:07 AM
  #108
thunder550's Avatar
Oh yeah, that's right. I actually put mine back into full closed loop. That's why I lost the commanded AFR table. Makes sense.
Old 11-13-2007, 10:07 AM
  #109
Yogi Bear's Avatar
I just found this thread. Congrats on an awesome build, KB!
Old 11-17-2007, 05:14 PM
  #110
kbracing96's Avatar
Up DATE TIME!!!
Ok guys, FINALLY got to drive the beast . and man she runs GOOD! Only running 5psi right now, and a VERY conservative tune till I have time to dial it in. I need to do some more work on the front steering though, has some really bad bump steer, so I think I'm gona have to put cross over steering on it. It's riding pretty rough too, but I think the box will help that, if not, I'm gona put some 1500# sleeve type bags in the back, and they should ride better. I got my seats put in too.
Oh, and their's a video in here for all you video freaks too,
Quick Reply: 72 4x4 MP T70 turbo 5.3 and bags buildup
