72 4x4 MP T70 turbo 5.3 and bags buildup
Old 11-05-2007, 12:33 PM
  #81
kbracing96's Avatar
Originally Posted by thunder550
That's what you said last week!
But I never said WHAT week
Old 11-06-2007, 12:05 PM
  #82
thunderwagen's Avatar
You sound like the guy who has been working on my fence for the last two years..........
Old 11-06-2007, 12:41 PM
  #83
kbracing96's Avatar
It's coming along very quickly now that I'm working on it every day
Old 11-06-2007, 03:11 PM
  #84
High on diesel fumes
thunder550's Avatar
It's about freaking time!!
Old 11-06-2007, 03:18 PM
  #85
UBLUZIN03's Avatar
looks awsome..what did you use to paint the frame?
Old 11-06-2007, 03:39 PM
  #86
kbracing96's Avatar
It's just Krylon Semi-flat black . Will get a nice frame off and detailed painting along with the body in a couple years. For now it gona just be all go and not much show
Old 11-11-2007, 08:19 PM
  #87
kbracing96's Avatar
Well, got her running today and she runs pretty good!. Still got some work to do to be able to drive it (gota put the carpet and seats in it still, but had it idling and revved it for about 30 minutes on the jack stands. Got all the fluids topped off, and the tranny works! I was skerd of it cuz I had to take all the guts out of it to get to 1 little stupid snap ring, so I could change out the out put shaft for the NP205 transfer case. I also put a TG shift kit in it when I did that and anytime I work on a tranny I'm AMAZED when it works after I get done
I have a couple small problems like a leak in the Vband coupler in the cross over pipe, but the problem that has me most confused is that the PCM won't turn on the fuel pump relay. The pin out diagram I have for it shows that pin 9 (grn w/white strip) on the C2 green conector is the primary fuel pump relay control, that I connected to the ground on the FP relay, and it doesn't work. The only code it's throwing is fuel pump relay control not working (go figure). Any ideas?
Old 11-11-2007, 08:28 PM
  #88
gonzo 6.2's Avatar
Awesome,get'r on the road ASAP
Old 11-11-2007, 08:52 PM
  #89
kbracing96's Avatar
BELIEVE me, I want to drive this thing! Got the fuel pump problem fixed, found out the PCM provides power to the solenoid, not a ground like most everything else it controls
Old 11-11-2007, 11:33 PM
  #90
thunder550's Avatar
Yaaaay! It lives!
Quick Reply: 72 4x4 MP T70 turbo 5.3 and bags buildup
