BlackGMC build take 2 - Turbo Time
Old 02-10-2013, 05:06 PM
  #121
Resident Retard
BlackGMC's Avatar
I did some tuning today. I am at 15* still at 8-9psi. I will probably go up to 16-17*. It is running pretty good
BlackGMC is offline
Old 02-10-2013, 05:42 PM
  #122
GMCtrk's Avatar
Where are you tuning it (highway?) and what gear?
GMCtrk is offline
Old 02-10-2013, 08:48 PM
  #123
Resident Retard
BlackGMC's Avatar
highway, i am tuning at WOT in every gear except 1st... 2nd is kinda a handful but still good... 4th gear loads the turbo just fine to get to 8-9psi at 2200rpm...
BlackGMC is offline
Old 02-10-2013, 09:28 PM
  #124
05stepside's Avatar
What is your 2nd gear roll?
05stepside is offline
Old 02-10-2013, 09:30 PM
  #125
GMCtrk's Avatar
Youre getting 8-9 psi at wot or part throttle in 4th?
GMCtrk is offline
Old 02-10-2013, 09:35 PM
  #126
Resident Retard
BlackGMC's Avatar
What boost? I am confused on what your asking
8-9psi at 50-56% tps, i still have not gone above 70% tps. Definitely not 100%. If i did the tires would go up in flames.
BlackGMC is offline
Old 02-10-2013, 09:41 PM
  #127
Resident Retard
BlackGMC's Avatar
correction, rolling into the throttle at 2200 in 4th 42% tps, starts at 1psi, the at 2500 it is at 8psi at 54% tps... Building boost with this setup is super easy.... I have a set of 3.42s but i am thinking about sending them back for some 3.73s since i really don't have an issue building boost...
BlackGMC is offline
Old 02-10-2013, 09:45 PM
  #128
Resident Retard
BlackGMC's Avatar
also it appears that the meth is dropping my IATs 10-15* on each pull... it goes as low as 48* and it was a was about mid 60s today I am really liking the METH!
BlackGMC is offline
Old 02-10-2013, 10:08 PM
  #129
GMCtrk's Avatar
That's nice part throttle boost man. What's your timing and AFR during those 4th gear rolls?
GMCtrk is offline
Old 02-10-2013, 10:16 PM
  #130
Resident Retard
BlackGMC's Avatar
15* and 11.2 AFR, meth turns on about 3-4psi...
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
