Honestly i have tried a couple of times, but everytime i do, the tires break loose and it start frying the tires. Holding a camera while doing that is nuts... i guess i could post up some bloopers...
That's crazy that you're frying them so bad! Anything under 40 mine fries, but at highway speeds (60+) I can mash it with no traction issues...although I am on heavy factory 20s with 275s.
Are you taking the truck to the track any time soon?
How much boost are you running? I could fry mine at 80 but I'd also have to be running 16lbs or so. At 12 I was fine...then again your and I's suspension is different as are our tires.
my truck was a tire frier N/A anywhere in 1st gear. tried several different tires. with a 555r I could roll into the throttle from a dig and be into a 150 shot before 1st gear shifted out.
