BlackGMC build take 2 - Turbo Time
For the interim yep. I got tired of making fuel lines. The Aeromotive instructions said it was ok but ideally the fpr needs to be after the rails. My fuel pressure holds just fine and increases with boost like it should.
I have all the fittings, hose and fuel rails ready togo i just need some time to install them.
Here are the rails
Here are the rails
Check Valves all installed. I installed on the the fresh air side of the PCV inlet because i did not want it sucking any oil/vapor from the motor when i really turn the turbo up. Not sure if pre-turbo will ever get much suction but i have seen a few guys colaspe air filters on turbo setups due to sucking in air. Anyways looks kinda cool plus i have like a billion AN fittings.
Please excuse the state of my wiring. It is on the list to clean up.
Btw the checks valves are sold by Boomba Racing
Check Valve inbetween the catch can and intake
And finally one on the brake booster. I had this one laying around left over from something
