BlackGMC build take 2 - Turbo Time
Old 06-29-2013, 12:41 PM
  #211
supercharged680's Avatar
Looks really good!
supercharged680 is offline
Old 06-29-2013, 06:54 PM
  #212
No it wont stick to aluminum...I had one broke off in the very back drivers side head caught the sound deadner stuff on the firewall on fire but finally got it out. Its a pain in the *** but a lot easier than removing the head.
1969x11 is offline
Old 06-29-2013, 07:25 PM
  #213
Resident Retard
BlackGMC's Avatar
Hmmmm. Yeah i dunno able welding it on the truck. I will just have to wait and see. It is at the very back.
I will probably start next week on it. After doing the suspension stuff over the last week i am wore out. But that damn exhaust leak is pissing me off, it is sooooo annoying.
BlackGMC is offline
Old 06-30-2013, 09:30 AM
  #214
Hunt&Fisherator
silver-mod-o's Avatar
This is what you need. If you have a right angle drill, no welding and I know these work. I've used this set for exactly the broken bolt you're talking about...
SE100 25 PIECE SCREW EXTRACTOR SET
silver-mod-o is offline
Old 06-30-2013, 12:15 PM
  #215
99LsSilverado's Avatar
But try with a left hand drill bit. If its not seized in the head it might turn out with the drill bit
99LsSilverado is offline
Old 06-30-2013, 02:15 PM
  #216
brandon6.0's Avatar
or drill it out and tap it for the next size up bolt. Thats what i did with my old heads. Same bolt hole to.
brandon6.0 is offline
Old 06-30-2013, 02:43 PM
  #217
Resident Retard
BlackGMC's Avatar
I got a heli coil set here just incase and i just ordered a set of left handed drill bits.
BlackGMC is offline
Old 07-05-2013, 12:10 AM
  #218
Resident Retard
BlackGMC's Avatar
WOOOOO HOOOOOO, there was not a bolt broken off in that head. The threads were just screwed up. I was able to run a tap into it and not everything is good!!! Thank goodness, i was not looking forward to removing the head.
On a side note, when i dropped the oil pan and removed the oil pump and pickup tube, the pickup tube screen was covered in ****!! It looks like some gooey RTV type of **** and perhaps brissles from a brush... Anyways, i am sure that was not helping out my oil pressure...
BlackGMC is offline
Old 07-05-2013, 12:38 AM
  #219
GMCtrk's Avatar
Good deal. When will you up the boost?
GMCtrk is offline
Old 07-05-2013, 12:54 AM
  #220
Resident Retard
BlackGMC's Avatar
hopefully next week, honestly i am happy with it the way it is. I have let a few friends drive it and they are really surprised on how well it runs at 8psi...
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
