BlackGMC build take 2 - Turbo Time
Old 07-23-2013, 12:20 PM
  #271
03sierraslt's Avatar
You need a couple more guages.
03sierraslt is offline
Old 07-23-2013, 12:22 PM
  #272
Resident Retard
BlackGMC's Avatar
Honestly i have been looking at a transmission pressure gauge
BlackGMC is offline
Old 07-23-2013, 12:59 PM
  #273
I have a gauge for that
Atomic's Avatar
Originally Posted by Beatdown Z
Starting to look like the inside of Atomic's truck...
Basically the look im going for
I use -8 with mine. Have about 50psi at cold idle with light spring in melling pump, about 40psi hot idle.
Atomic is offline
Old 07-23-2013, 01:04 PM
  #274
Why? I mean I know why but, why?
Old 07-23-2013, 01:14 PM
  #275
Laid Back
Beatdown Z's Avatar
I hate gauges. They always end up being bearers of bad news.
Beatdown Z is offline
Old 07-23-2013, 01:31 PM
  #276
TXsilverado's Avatar
then you need gauges to monitor your gauges. i was going to go crazy on the gauges on my truck until i figured out the prices of aftermarket gauges. i'll keep my OEM stuff thanks lol. gauges make me worry about, and over ****-ize stuff.
TXsilverado is offline
Old 07-23-2013, 01:35 PM
  #277
Resident Retard
BlackGMC's Avatar
Hmmm, i have a ton of left over -8 fittings and hose, think i should use -8 instead of -10? The only reason i went with -10 was due to all the pre-assembled kits i have seen on various sites....
just to monitor the health of the tranny, alot can be determined by monitoring that pressure... For example if your max pressure is 100psi, that would be bad...
BlackGMC is offline
Old 07-23-2013, 01:38 PM
  #278
Atomic's Avatar
-8 or -10 will be fine, I just had more -8 left over and my original block was machined for -10 so I had to use that. The new block (like yours) is 3/8npt so I could use -8 and eliminate all the adapters I had to use.
Atomic is offline
Old 07-23-2013, 07:12 PM
  #279
Marlin4549's Avatar
Nice work man. can't wait to start building my 02 gmc single cab
Marlin4549 is offline
Old 07-23-2013, 09:18 PM
  #280
Resident Retard
BlackGMC's Avatar
Well i got the oil temp gauge hooked up and went for s short 5 min drive no boost, just cruising in grandpa mode. The temp steadily climbed to 210* when i finally shut it off. It is only like 85-90* out right now. So tomorrow will be interesting when i drive it to work in the 105* temps. Also my EGTs only got up to 950*. Normally at cruise they get to 1000-1050*. So this will be a good test to see if i really need to add the cooler or not.
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
