BlackGMC build take 2 - Turbo Time
#277
just to monitor the health of the tranny, alot can be determined by monitoring that pressure... For example if your max pressure is 100psi, that would be bad...
#280
Well i got the oil temp gauge hooked up and went for s short 5 min drive no boost, just cruising in grandpa mode. The temp steadily climbed to 210* when i finally shut it off. It is only like 85-90* out right now. So tomorrow will be interesting when i drive it to work in the 105* temps. Also my EGTs only got up to 950*. Normally at cruise they get to 1000-1050*. So this will be a good test to see if i really need to add the cooler or not.
