BlackGMC build take 2 - Turbo Time
Old 12-04-2013, 09:39 PM
  #291
Resident Retard
BlackGMC's Avatar
Wow been awhile since i did anything to the truck.
Anyways it has been almost 1 year since i installed the turbo. It has taken about that long to work out all the bugs and tweak some things. This is actually my first time tuning a FI vehicle so that was rather slow going.
The truck has run has been a blast to drive and i have had no real issues.
Sooooo i figured it was time to finally up the boost so i ordered a AMS-500 dual stage boost controler. Still trying to figure out where to mount everything and measuring for all the -3 teflon braided lines to hook everything up.
Pile of lines, these are leftovers hopefully they fit somewhere
BlackGMC is offline
Old 12-04-2013, 10:32 PM
  #292
oakley6575's Avatar
Cool bud! How much boost are you planning to run and how much are you running right now?
oakley6575 is offline
Old 12-04-2013, 10:54 PM
  #293
I have a gauge for that
Atomic's Avatar
You know stainless line and AN fittings is way overkill for that right?
Atomic is offline
Old 12-04-2013, 11:01 PM
  #294
Resident Retard
BlackGMC's Avatar
yep i know. All my air lines are like that. I used to have all rubber lines and it worked fine until one died, that is when i switch them all over so know i don't have to worry about it.
Also it realy isn't that expensive. One of the lines are like $15. I buy them premade at a circle track race shop.
BlackGMC is offline
Old 12-04-2013, 11:02 PM
  #295
Resident Retard
BlackGMC's Avatar
probably start out with 10, then 12, then 14... I just depends if it starts spinning like a retard, then there is no point it going higher...
BlackGMC is offline
Old 12-19-2013, 01:17 AM
  #296
FormerVendor
carsonhowe22's Avatar
Gotta love turbos!
carsonhowe22 is offline
Old 12-19-2013, 06:34 AM
  #297
Byrdman11's Avatar
Lookin good. I'm mounting my boost controller in the glove box and running everything under the truck out of a floor drain plug at the right front seat.
Byrdman11 is offline
Old 12-19-2013, 01:50 PM
  #298
Resident Retard
BlackGMC's Avatar
Yeah i cant decide where to mount the boost controller either the glove compartment or under the hood.
BlackGMC is offline
Old 12-21-2013, 01:37 PM
  #299
Resident Retard
BlackGMC's Avatar
I got everything all plumbed up just working on the wiring. So i will be able to run 3 stages of boost. Off the spring 6lbs, stage 1 8lbs, stage 2 12lbs. Something like that.
Solenoids mounted
Switch panel: stage 1, stage 2, meth test, fans low, second fuel pump
I still need to paint it
BlackGMC is offline
Old 12-21-2013, 01:55 PM
  #300
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Race truck
1slow01Z71 is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
