BlackGMC build take 2 - Turbo Time
Old 01-01-2014, 02:14 PM
  #331
oakley6575's Avatar
Did you get it put back together?
oakley6575 is offline
Old 01-01-2014, 04:51 PM
  #332
Resident Retard
BlackGMC's Avatar
Still working on it. Everything is back together just working on getting the shims right to get the right backlash. I have had that carrier in/out about 3-4 times.
Also my retard moment of the day. The bolts that hold the ring gear on are reverse threads. I was not aware. When i removed the old gear set i just hit it with my new impact and broke every bolt. Awesomeness. I just figured they were locited i. From the previous install. The. When i put on the new ring gear i noticed they were reverse threaded.
BlackGMC is offline
Old 01-01-2014, 05:16 PM
  #333
oakley6575's Avatar
Thats pretty funny. What clearances are you setting everything to?
Old 01-01-2014, 05:34 PM
  #334
Resident Retard
BlackGMC's Avatar
0.005-0.006
It is currently at 0.010
BlackGMC is offline
Old 01-01-2014, 07:57 PM
  #335
Hunt&Fisherator
silver-mod-o's Avatar
Lefty tightey, righty loosey...
silver-mod-o is offline
Old 01-01-2014, 08:06 PM
  #336
03sierraslt's Avatar
COrey gon dun take out bolts......
We only laugh because you got it taken care of and no people or animals were hurt in the process.
03sierraslt is offline
Old 01-01-2014, 08:10 PM
  #337
Custm2500's Rude Friend
1FastBrick's Avatar
1FastBrick is offline
Old 01-01-2014, 09:56 PM
  #338
Resident Retard
BlackGMC's Avatar
Yep i am a retard. There were other retard moments but i wont mention those. But the wife and baby went to sleep sooooooo i went into the garage
I finally got the damn backlash to 0.005. I am quiting for the night.
BlackGMC is offline
Old 01-01-2014, 09:58 PM
  #339
1FastBrick's Avatar
come on now... lets hear those moments...
Old 01-01-2014, 10:06 PM
  #340
Resident Retard
BlackGMC's Avatar
Ok ok.
In the write it says to beat the pinion out with the old nut still attached. Well that worked great except the old nut end caves inward when you do that.
Then you go reassemble the new pinion with the old nut. Well it threads about 3/4 of the on there then it starts breaking apart. Pieces of metal poking out the end. Well i thought i screwed the ned pinion up. Luckily it was just the nut. After getting it off i hit it with the grinder and all is well.
Oh and the smell of gear oil is horrible. I forgot to take off my shoes and i tracked that **** all in the house. Luckily it was on the tile.
I am sure there are more. Honestly somedays i shouldn't own tools
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
