BlackGMC build take 2 - Turbo Time
#711
Well i drove the truck today. The gears make zero noise which is great. The truck pulls more vacuum cruising down the highway which is great.
Now on to the bad.
I have to replace the AC belt tensioner because it makes a squeak.
Also for some reason the firewall or dash make some kinda awful noise. Almost like it is vibrating against something. It only does it when RPMs are low but under a heavy load like when in 4th going up a hill. It is really annoying. I gotta figure that out.
Now on to the bad.
#712
Custm2500's Rude Friend
Well i drive the truck today. The gear make zero noise which is great. The tru k pulls more vacuum cruising down the highway which is great.
Now on to the bad.
I think i gotta replace the AC belt tensioner because it is make a squeak.
Now on to the bad.
This Noise obviously rattled your brain more then normal as your post is Painful to read...
#715
I figured out the noise. It is the fuel lines... The hose ends with these PTFE lines are a double swivel. When the hose moves slightly the swivel tilts which pulses with the pump.. Temporarily i got them zip tied so they don't move. I am gonna make a bracket to hold them in place.
Problem of the day. Apparently the Power Steering pump i bought is a pile of ****. It works sometimes... So i am gonna order an ACDelco one...
Tuning is going rather well. I still don't have the METh hooked up so i am keeping it under 5psi. The truck feels real strong with the new gears.
hopefully i can get the meth controller wired up and work out the rest of the bugs in the next few weeks...
#717
Do it the old fashion way.
Just jack the front end up and turn the wheels lock to lock like 15 times slowly. Then let it sit for a minute or two and do it 5-10 more times. Start the truck and shut it off after a second or two to get the fluid moving and do the whole thing again and that should get any little air bubbles out.
