BlackGMC build take 2 - Turbo Time
#724
Yeah. I am looking at brand new delco pumps.
I read some interesting things last night about this. First i did not flush out the system, oops. Second, i used power steering fluid and not dexcron/atf fluid. Some people aaid it make a difference. I dunno.
Anyways. Hopefully i will have it switched out by this weekend and be back in business.
#727
I got the PS pump swapped out today with a brand new ACDelco. The PS works great now.
I also put on the correct 145a alternator. Another brand new ACDelco. I had a Reman 145a from a 06-07 which does not work very well. Now i have no idle hit when AC and/or fans kick on which is great.
Apparently the new alternator sticks out about 1/8-1/4 further than the old one. Whicj is causing the belt to slide off the crank. So i gotta grind down the mounts slightly. No biggie.
That noise i mentioned earlier is still there and no way it is the fuel lines. I am thinking it is some how exhaust or turbo related. It only does it when i am at heavy load. As soon as i give it gas and go into boost it goes away. Maybe it is the wastegate or something. I dunno i am at a loss.
