BlackGMC build take 2 - Turbo Time
#774
I think i fixed the belt alignment issue. Time will tell. I am gonna pick up an OEM belt at the stealership tomorrow. Thank goodness i have a buddy that works at the cadilac dealership and he gets me parts at his cost. Seems like i have spent a fortune up there lately.
Now i just gotta finish up the meth controller wiring and i am done.
#776
Well i finally figured out the belt issue. Apparently i bent the damn alternator bracket. The ear that mounts the idler pulley was bent outwards causing the pulley to not line up and belt wanting to ride off the crank. I bent the bracket back straight and the test drive went well. The bracket is 3/8 Aluminum. So i found another company that makes a 3/4 thick bracket that is alot beefier so i ordered it.
Also i built an new efan harness. I got all the components from racetronix. All new relays and fuse holders. I got efan connectors from the stealership. I made redundant grounds in several places and used all 10 gauge wiring. When the fans kick on high with the AC on full blast. The idle is rock solid and no voltage dip. Hopefully i am good now.
I should have the truck all tuned up this week now that the METH kit is all wired in and working. I am ready for this project to be over with so i can enjoy the truck.
